Thread: Hub Center Bore?
Results 1 to 5 of 5
  1. #1 Hub Center Bore?
    Donating Users Mr D's Avatar
    Nov 2011
    Chicago
    03 GTP
    I'm looking at a set of used Elbrus IO4 wheels that have a Hub Center Bore of 67.1. My internet reference lists my OE as 70.3. Dumb question, will the wheel w/ smaller hub center bore fit my gtp? Any accessories, hardware, adapters reuired?
    Thanks in advance to anyone with 1st hand knowledge that can help me out.
  2. #2 Re: Hub Center Bore?
    No it wont fit.
    It either has to be the same bore and bolt pattern or the bore can be bigger and you have to use hub centric rings.
  3. #3 Re: Hub Center Bore?
    it'll fit with a spacer that will make the rear of the hub sit flush on something.
    not necessarily recommended, but lots of people do it.
    Jan 2009
    Tallahassee, FL
    Or you can have the hub bore milled to match.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  5. #5 Re: Hub Center Bore?
    Nov 2011
    Chicago
    Thanks for the input guys, greatly appreciated--esp. since the wheels are about hr drive away, ea. way.
  1. Brake Bore Inlet Size
    By Bedwards in forum Brakes/Suspension/Chassis
    Last Post: 05-01-2011, 10:46 AM
  2. bore an LS4?
    By jlt695 in forum 5.3L V8 (LS4)
    Last Post: 01-26-2011, 01:05 PM
  3. bore an ls4?
    Last Post: 01-26-2011, 10:29 AM
  4. Whats our hub bore size?
    By Agentlongwood in forum Tires & Wheels
    Last Post: 01-18-2010, 01:23 AM
