Thread: Had a Rotation--Now it's Nice and Noisy
Results 1 to 11 of 11
  1. #1 Had a Rotation--Now it's Nice and Noisy
    Apr 2011
    Ohio
    I had my tires rotated today (I destroyed the fronts, so swapped them to the back). Now the car handles well--the rubber that's now in the front are two Potenzas. The crappy old Vivas are now in the back. However, there's now a low rumbling from about 10-35, whether I'm speeding up or slowing down. It's not a drivetrain thing or anything, because it wasn't noticeable with the old tires. Anybody have any suggestions? I had the rotation done at Walmart, so who knows what they did.
    Thanks!
  2. #2 Re: Had a Rotation--Now it's Nice and Noisy
    I would suspect the destroyed tires first.
  3. #3 Re: Had a Rotation--Now it's Nice and Noisy
    Feel the inside part of the tread on both front tires.
    Do they feel like they have hills and valleys in them?
    And the they are potenza's, which LOVE to cup, and I bet thats the reason you are feeling that.
  4. #4 Re: Had a Rotation--Now it's Nice and Noisy
    GT Level Member ls1camino's Avatar
    Laurel, MD
    Are they directional tires? Did you switch sides with the rotation or just move them from front to back?
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  5. #5 Re: Had a Rotation--Now it's Nice and Noisy
    They are cupped or you changed the rotation direction.
  6. #6 Re: Had a Rotation--Now it's Nice and Noisy
    Apr 2011
    Ohio
    I just went out and checked--you guys are right. They're cupped to hell. Running my hand along the inside tread is like riding a roller coaster. What's the solution? Just an alignment? I've been considering redoing my suspension--the car has 133,333 on the clock and the original struts and springs. I wonder if it's the front or the back that's causing the problem? The tires were on the back so long that they could've been getting cupped while back there, and then it became noticeable when I swapped them to the front.
  7. #7 Re: Had a Rotation--Now it's Nice and Noisy
    You left them on the back too long without rotation.
    The tires will have to be replaced to fix the problem you are having.
    On your next set of tires, rotate every 5k miles and all will be good.
  8. #8 Re: Had a Rotation--Now it's Nice and Noisy
    Aug 2011
    'Merica
    I would rotate every 3k miles
  9. #9 Re: Had a Rotation--Now it's Nice and Noisy
    Pshhhh Cam they dont' need to be replaced, the cupping needs to be corrected.
    My method of fixing cupping entails my favorite air freshener "Tire Smoke". That'll fix them up.
  10. #10 Re: Had a Rotation--Now it's Nice and Noisy
    Apr 2011
    Ohio
    In order to prevent this from happening in the future, should I redo the rear struts? I've been considering some GR2s for some time now.
  11. #11 Re: Had a Rotation--Now it's Nice and Noisy
    Mainly the reason it happened was because they are potenza's and lack of rotation.
    If you rotate them every 5,000 miles, you wont have the issue again.
    Worn out struts on these cars, dont really cause the tires to cup.
  1. Noisy supercharger at air intake
    By Purple Plazma in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 09:46 AM
  2. Steering wheel shaking a little after tire rotation
    By Haulero in forum General Tech Discussion
    Last Post: 12-08-2009, 09:56 PM
  3. Noisy Supercharger. Bad Coupler?
    By JoelW98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2009, 05:57 PM
  4. noisy flex
    Last Post: 04-11-2009, 01:22 AM
  5. Tire Rotation by Idiots!
    By TFBuckeye in forum The Rant Forum
    Last Post: 01-04-2009, 05:40 PM
