Thread: i need a wheel and tire package to run mickey thompson et streets
Results 1 to 8 of 8
  1. #1 i need a wheel and tire package to run mickey thompson et streets
    May 2012
    Glen Allen, VA
    Hey guys, im new to forums so forgive me if Im not following any protocols, but I just got my car out to the strip for the first time in a couple years, I put in a ZZperformance transmission, and pulled a warranty stunt to get a brand new L32 long block that was put in as well, back then I could get away with using street tires and the car would hook up, now its blowin up the tires every time at the starting line. I want to run some mickey thompson et streets on it, but the closest size to stock they come in is a 255/50/17, so I want to know what size wheel I can use to fit that tire without anything rubbing
  2. #2 Re: i need a wheel and tire package to run mickey thompson et streets
    Feb 2009
    flintnasty MI
    255 50 17 should work ok (although I am not too familiar with 04+ stuff). If it starts to rub anything you should be able beat the offending parts into cooperation.
  3. #3 Re: i need a wheel and tire package to run mickey thompson et streets
    May 2012
    Glen Allen, VA
    Thats good to know, but im lookin for width and offset of the wheel im gonna have to use with them, obviously it has to be a 17 inch wheel haha
  4. #4 Re: i need a wheel and tire package to run mickey thompson et streets
    255 tire will fit snugly on anything 8.0/8.5" wide. that's what i would stick with.
    an offset of around +35mm to +40mm would be ideal.
  5. #5 Re: i need a wheel and tire package to run mickey thompson et streets
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Why dont you run some 255/50/16s. Its close enough to stock.
    But for the 17s. Get some 99-04 mustang gt (not bullits) rims. 17x8 and light
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  6. #6 Re: i need a wheel and tire package to run mickey thompson et streets
    Quote Originally Posted by Ridin ON Chrome View Post
    Wont those rub with that offset?
  7. #7 Re: i need a wheel and tire package to run mickey thompson et streets
    May 2012
    Glen Allen, VA
    Thanks for the input guys, I saw on another thread that a couple guys were running 26x9.5x16 hoosier quick time pros on the older SE wheels that are 16x8, might check that out
  8. #8 Re: i need a wheel and tire package to run mickey thompson et streets
    Houston/Baton Rouge
    No, they will be fine..
    Its only a 8" wide wheel not 9". Even though a 9" wide wheel will be fine for most setups
  1. Mickey thompson et streets - holes in sidewalls
    By aligater in forum Brakes/Suspension/Chassis
    Last Post: 02-15-2012, 06:30 PM
  2. wheel / tire questions.
    By TJWA07GXP in forum Introductions/Noob Questions
    Last Post: 01-18-2012, 01:41 PM
  3. Wheel and Tire question
    By zerolimitsgt in forum Tires & Wheels
    Last Post: 03-17-2010, 03:50 PM
  4. Lakeshore Wheel & Tire?
    By Sheepdog in forum General Tech Discussion
    Last Post: 08-04-2009, 01:13 AM
