Thread: if i have a 17 inch rim what tire size can i use?
Results 1 to 19 of 19
  1. #1 if i have a 17 inch rim what tire size can i use?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i have a 99 GTP and stock tire size is 225/60R16 if i put a 17'' rim from an 04+ grand prix on my car what tire size should i get so i dont mess with my speedo?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: if i have a 17 inch rim what tire size can i use?
    May 2008
    Winnipeg, MB
    225/55r17
    2007 Pontiac Grand Prix
  3. #3 Re: if i have a 17 inch rim what tire size can i use?
    Oct 2011
    Michigan
    is that what came stock on your 07 GP?
  4. #4 Re: if i have a 17 inch rim what tire size can i use?
    May 2008
    Winnipeg, MB
    yes
  5. #5 Re: if i have a 17 inch rim what tire size can i use?
    Out West
    Whine with your Cheese?
  6. #6 Re: if i have a 17 inch rim what tire size can i use?
    Oct 2011
    Michigan
    Quote Originally Posted by Nixon View Post
    245/45
    on a stock 04+ GP rim?
  7. #7 Re: if i have a 17 inch rim what tire size can i use?
    Out West
    Quote Originally Posted by asite57 View Post
    Sure! I run that size on that rim.
  8. #8 Re: if i have a 17 inch rim what tire size can i use?
    May 2008
    Winnipeg, MB
    go on Tire Rack - Your performance experts for tires and wheels and see what size they would use
  9. #9 Re: if i have a 17 inch rim what tire size can i use?
    Never Never Land
    Too small Nix. 3.6% too small
    225/55/17 is the correct size. However you can get a 245/50/17 if you want a little wider tire. Exact same overall size as the oem size.
  10. #10 Re: if i have a 17 inch rim what tire size can i use?
    Out West
    3.6% means dick. more aggressive tire which looks nicer than stock.
  11. #11 Re: if i have a 17 inch rim what tire size can i use?
    plus or minus 3% is usually in the safe region to change around sizes.
  12. #12 Re: if i have a 17 inch rim what tire size can i use?
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    Im running 245/45/17 and i love them,my speedo is 3km/h off no biggie
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  13. #13 Re: if i have a 17 inch rim what tire size can i use?
    Donating User Odi's Avatar
    Chicago South Suburbs
    245 45 17 make the wheelgap worse.
  14. #14 Re: if i have a 17 inch rim what tire size can i use?
    Out West
    yeah but fat sidewall is weaksauce unless slick status.
  15. #15 Re: if i have a 17 inch rim what tire size can i use?
    ill take fat tire > more wheelgap.
  16. #16 Re: if i have a 17 inch rim what tire size can i use?
    Oct 2011
    Michigan
    what does weaksauce mean?
  17. #17 Re: if i have a 17 inch rim what tire size can i use?
    Never Never Land
    Agreed Odi. A bigger tire will fill in the wheel gap more and look a little better
  18. #18 Re: if i have a 17 inch rim what tire size can i use?
    Oct 2011
    Michigan
    what do you all think?
  19. #19 Re: if i have a 17 inch rim what tire size can i use?
    Oct 2011
    Michigan
    alright i bought the rims i only payed $200 for all 4 they were in good shape one had a little curb rash and one was a little bent a tire shop told me it should leak or wobble at all heres some pics
    http://i813.photobucket.com/albums/z...507_180220.jpg
    http://i813.photobucket.com/albums/z...507_180230.jpg
    http://i813.photobucket.com/albums/z...507_180239.jpg
    http://i813.photobucket.com/albums/z...507_180633.jpg
  1. Tire Size
    By jamster00 in forum Tires & Wheels
    Last Post: 12-13-2011, 01:29 AM
  2. What size tire can I fit???
    By Bigbm80 in forum Tires & Wheels
    Last Post: 04-28-2010, 10:02 PM
  3. What size tire can I fit???
    Last Post: 10-06-2009, 10:05 AM
  4. 20" inch tire size
    By og512 in forum Tires & Wheels
    Last Post: 07-28-2009, 03:47 AM
  5. What size of tire do i need?
    By cboth686 in forum Tires & Wheels
    Last Post: 04-03-2009, 07:17 PM
