Thread: 5x115 vs 5x114.3 Official Debate
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: 5x115 vs 5x114.3 Official Debate
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I wouldn't use 114.3mm.
    But I also wouldn't trust using sleeves over the caliper bolts, as many do when upgrading calipers.
  2. #22 Re: 5x115 vs 5x114.3 Official Debate
    michigan
    Quote Originally Posted by lrscgod View Post
    Discount tire, there's your first problem...LOL
    I only went there cuz theyre one of the only TSW wheel distributors around me. Come to find out my wheel that is bent is discontinued.....fml.
  3. #23 Re: 5x115 vs 5x114.3 Official Debate
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by NegativeOne13 View Post
    MRW - How to measure bolt pattern
    From center to outside of opposing hole. Like I said, the 0.7mm is minute, but does make a difference. Not enough distance to be overly concerned in my opinion. That is the purpose of the hubcentric to reduce stress on any lug that may have uneven pulling pressure from the wheel not being centered.
    But you dont need hubcentric rings to run mustang wheels. Since there hub bore is almost the same diameter as ours. Thats why running 114.3 rims is no big deal.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  4. #24 Re: 5x115 vs 5x114.3 Official Debate
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    Quote Originally Posted by twol8uluz View Post
    That blows!
    4 out of 3 people have trouble with fractions
  5. #25 Re: 5x115 vs 5x114.3 Official Debate
    I just had a guy from discount tire tell me that he wouldnt mount a 114.3 wheel on my car........then i walked out laughing.
    why do you need people to mount your wheels for you? you only need them for the mounting of the tires and that's it.
  6. #26 Re: 5x115 vs 5x114.3 Official Debate
    michigan
    I dont. But seeing i wouldve already been there getting tires mounted it only makes life a bit easier than having to throw on my spare, drive home, then throw it on. Doesnt matter....im shxt outta luck anyways. Lol
  7. #27 Re: 5x115 vs 5x114.3 Official Debate
    Kansas
    Quote Originally Posted by Ridin ON Chrome View Post
    I was talking about rims in general, plus op is talking about MSR rims.
    Jan 2009
    Tallahassee, FL
    Probably for liability, a shop like that isn't going to mount a wheel that isn't the cars correct lug pattern.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  9. #29 Re: 5x115 vs 5x114.3 Official Debate
    SE Level Member Ricky Bobby's Avatar
    Apr 2012
    Massachusetts
    Ok so 5x114.3 wont be a problem. What is everyone using for offset? Im going to do the KV5's in 19x8.5 and im thinking +40 offset? Im also doing the GXP calipers front and rear if that makes a difference clearance wise.
  10. #30 Re: 5x115 vs 5x114.3 Official Debate
    Jan 2009
    Tallahassee, FL
    After my spacers come in my 9" wheels will be at +30, might could do +25mm
    77 Morris Garage B
  11. #31 Re: 5x115 vs 5x114.3 Official Debate
    michigan
    Id say 30 would be ur max before they start sticking out tremendously and not look good. Imo i think 40 would be good.
  12. #32 Re: 5x115 vs 5x114.3 Official Debate
    with an 8.5" width you'll probably want about a +35mm offset for the flush look. however, you can always go around +40mm and add a small spacer if you'd like, which is what i would do to be safe.
    also, rolling the fenders is easy. don't let that scare you.
  13. #33 Re: 5x115 vs 5x114.3 Official Debate
    SE Level Member tomasz26's Avatar
    Aug 2011
    detroit
    Fronts are 18x8 and rears are 18x9, and riding on B&G springs.
    How much did it cost you to install the lowering springs? What did you buy exactly to do it besides springs? Did you do it yourself?
  14. #34 Re: 5x115 vs 5x114.3 Official Debate
    Donating User Odi's Avatar
    Chicago South Suburbs
    Quote Originally Posted by mechguy View Post
    youre talking about GM. you should be wondering if that lazy line worker that assembled the car tightened all the bolts right.
  15. #35 Re: 5x115 vs 5x114.3 Official Debate
    GTX Level Member Bakerdd's Avatar
    Raleigh, NC
    Whats the deal with wobble bolts? I never really hear them mentioned around here but thats what everyone suggests on a few other forums i check
  16. #36 Re: 5x115 vs 5x114.3 Official Debate
    ^^ ive seen them used before. its used for example on 4x100 to 4x98 bolt patterns. 0.7 mm isnt worth getting them, plenty people here running stock bolts YEARS without issues.
  17. #37 Re: 5x115 vs 5x114.3 Official Debate
    Dec 2008
    Lawndale, CA
    Been on 5x114.3 for 5 years now with no issues.
  18. #38 Re: 5x115 vs 5x114.3 Official Debate
    Minnesota
    From what I have heard seen and read....Most companies just make the bolt pattern on wheels at 5x115 or 114.3 but not both....Meaning they don't make two different wheels, they are the same but just listed as two sizes.
  19. #39 Re: 5x115 vs 5x114.3 Official Debate
    they are the 'same' because they are so close they dont have to consider them different.
    however, in the real world they are different.
  20. #40 Re: 5x115 vs 5x114.3 Official Debate
    Houston/Baton Rouge
    Many big wheels companys make both now.
    But if you looking for that special wheel. Its only going to come in 5x114.3
  1. Sub debate
    By jjliebe9110 in forum Audio, Security & Visual Electronics
    Last Post: 11-29-2011, 04:38 AM
  2. so if 5x114.3 fits...does 5x114?
    By cboth686 in forum Tires & Wheels
    Last Post: 04-24-2009, 04:36 PM
  3. 5x115 1" Wheel Spacers
    By armcclure in forum Tires & Wheels
    Last Post: 10-12-2008, 01:22 PM
