Thread: 20's..any issues?
Results 1 to 20 of 30
  1. #1 20's..any issues?
    SE Level Member bziggy58's Avatar
    Apr 2011
    Minnesota
    I have an 08 grand prix all stock as far as body and chassis goes. I want to buy some 20s with 245/35/20. Anyone else run this set up? Any rubbing or problems?
  2. #2 Re: 20's..any issues?
    Omaha, NE
    I don't know about rubbing, but you're going to open yourself up to a possibility for some transmission problems.
  4. #4 Re: 20's..any issues?
    Apr 2011
    Minnesota
    Im a certified mechanic so mechanically im not worried I don't do much for "beating" on the car but I just want to assure they shouldn't rub for me, thanks for the help
  5. #5 Re: 20's..any issues?
    Out West
    Just image issues really unless you beat on it.
    Keep it classy.
    Whine with your Cheese?
  6. #6 Re: 20's..any issues?
    SE Level Member tomasz26's Avatar
    Aug 2011
    detroit
    I had 20s with that same exact tire size on my 04 GP for awhile they were pretty sweet and I never ever had rubbing issues due to my turn radius. I did however have slight cuts in the rear tires because the fenders would sway down if I hit a large bump at a high speed. I also live in Michigan so big bumps are very very popular But I easily solved the issue by putting small plastic guards over the edge that was cutting the tire (don't worry you couldn't notice them on the car just by looking) You will be fine though, if anything I thought the 20s started to look small on my car thats why I'm switching to 18s with some tread so I can get my performance back
    Let me know what you decide to do and post some pics!
    Good luck man
  7. #7 Re: 20's..any issues?
    Apr 2011
    Minnesota
    I will show you as soon as its done but it will probably be a bit yet. Im looking at the boss 304 I think the number was but the offset will never work. But as soon as I do it ill show you. Thanks for the help!
  8. #8 Re: 20's..any issues?
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by bziggy58 View Post
    Yeah, looks like they have some los offsets for the 20s
    Style 304 Specifications - Truck & SUV Wheels - BOSS Wheels
    The +26s might work, but they be sticking out a good bit. Good thing there only 8.5" wide.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  9. #9 Re: 20's..any issues?
    Apr 2011
    Minnesota
    Yeah that's my concern so ill have to find something else. I here that 35 to 42 is spouse to be ok tho
  10. #10 Re: 20's..any issues?
    that's probably what you'll want to stick with so you don't have to worry so much about rubbing issues and mexi-poke.
  11. #11 Re: 20's..any issues?
    I live here. TLSheff's Avatar
    Get the fenders rolled, maybe pulled a little depending on the size and offset of the wheel/tires and you should be fine.
  12. #12 Re: 20's..any issues?
    Apr 2011
    Minnesota
    im looking into the boss 340 now, closer to factory offset with 245/35/20. I can get a pretty good deal through work so it looks like the time is coming any opnions on the wheel setup, anything that looks like it might cause an issue with this set up. I really dont want to have to cut or roll my fenders.
  13. #13 Re: 20's..any issues?
    Houston/Baton Rouge
    I like them..
    They will fit fine with the +38 offset. You getting chrome?
  14. #14 Re: 20's..any issues?
    rolling the fenders is easy. if you cut the fenders you're a noob and want a rusty car.
  15. #15 Re: 20's..any issues?
    I think its silly to get nice rims and tires and NOT roll the fenders at the very least, better safe than sorry
  16. #16 Re: 20's..any issues?
    mine are rolled completely flat and have a slight pull to them. i still rub.
  17. #17 Re: 20's..any issues?
    Apr 2012
    nova
    i rolled the fenders on my mr2 and still rubbed like a ***** haha
    1999 gtp coupe... P&P heads, lim, and sc, comp vs cam, intake, dp and ubend
    2003 ford ranger fx4 level II- twin stick
  18. #18 Re: 20's..any issues?
    ^^^ x2 Exactly!!! Imagine if you hadn't rolled them. Its silly not too. I haven't yet and as long as there isn't any weight in the back, or as long as I don't hit a big bump I don't rub, but the tires have a couple rub spots so it needs to be done... Will prolly do that this weekend if I find time.
  19. #19 Re: 20's..any issues?
    Apr 2011
    Minnesota
    yeah im going chrome, i guess i will roll the fenders, i just never have im kinda intimadated lol, pretty easy?
  20. #20 Re: 20's..any issues?
    search around, there's lots of resources. just dont do it a hack job way with a baseball bat or a phone book.
  1. Just got a 98 GTP has issues lol
    By beno420 in forum Introductions/Noob Questions
    Last Post: 05-17-2011, 10:14 PM
  2. H.I.D Issues...need help?
    By Pontiacman76 in forum Audio, Security & Visual Electronics
    Last Post: 05-13-2011, 08:23 PM
  3. a few odd issues
    By Spartan GL in forum General Tech Discussion
    Last Post: 05-21-2010, 09:14 AM
  4. 05' gp gt issues!!!! - please help!!
    By Billyb in forum General Tech Discussion
    Last Post: 05-17-2009, 09:20 PM
  5. BOV issues
    By rodman in forum Turbo
    Last Post: 03-27-2009, 09:00 PM
