Thread: need some tire advice
Results 41 to 60 of 71
  1. #41 Re: need some tire advice
    Quote Originally Posted by crazyguy03 View Post
    zeon RS3-a OR the zeon RS3-S (summer only)
    Rated #2 by consumer report and are amazing IMO
    I just bought them in 245-50-16 but I have 7" wheels
    3% speedo difference cant be much as this was a dealer option avail in 2003
    track times? (aka empirical evidence)
  2. #42 Re: need some tire advice
    Donating User Odi's Avatar
    Chicago South Suburbs
    wheel gap is worse than sidewall height. makes it look mexi.
  3. #43 Re: need some tire advice
    Apr 2009
    Fort Worth TX
    asite57
    Are you Mexican?
  4. #44 Re: need some tire advice
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    No sir I'm white
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  5. #45 Re: need some tire advice
    GTX Level Member blackflag's Avatar
    Virginia
    get some spacers to go with that then you'd have some latin street cred.
  6. #46 Re: need some tire advice
    Oct 2011
    Michigan
    no lol its only a 3/4 of an inch difference
  7. #47 Re: need some tire advice
    You could go to the junkyard or if you have a friend with a 99+ grand am with 16" rims put those on your car and see if you like the tire look better. They come with 225/55/16
    Buffalo
    Dont have any yet. Plus i doubt I would abuse these on a track. Look at the YouTube reviews and google from other users who have purchased them. I spent a week researching Price plus reviews seemed like a great deal. Btw it's an UHP-AS so it will outlast a softer summer-only tire like a KDW
    2nd I doubt any advice given in this thread is being taken seriously lol
    Either way, I couldn't be happier
    http://www.treaddepot.com/review/ZRS3A.html
  9. #49 Re: need some tire advice
    SWPA
    225/50/16 is only 25.85" tall aka almost 2" shorter than stock.
    Even 225/55/16 is still an inch shorter than stock.
  10. #50 Re: need some tire advice
    not to mention the most important fact: your speedo will be off by an annoyingly high ammount.
    Buffalo
    From a 225/60/16 to a 245/50/16 ? Hmmmm. I doubt it's gonna off a lot
    60 mph x 3% would 1.8mph faster
    Remember then regal gs had 225/60/16 and in 2003 there was an gsx option where it could outfitted with a gsx wheel running 245/50/16s
  12. #52 Re: need some tire advice
    SWPA
    225/60/16 = 26.63" tall
    245/50/16 = 25.65" tall
    1" shorter and around 3 mph off at 60 mph. Its going to put more miles on than you are actually going. When you are showing 60mph you are only actuall going about 57.
    Buffalo
    Well all I'm saying is that you could buy it that way.
    Besides you can use hpt and enter those measurements
  14. #54 Re: need some tire advice
    SWPA
    But HPT can't fix the 1" extra wheel gap it gives you.
    I swear this is the first forum I have been on that actually has people suggest going to a smaller diameter tire. I find it absolutely ridiculous. Every other forum I am apart of would never suggest such a thing.
    Buffalo
    I suggested the tire not the size
    I also stated how that tire size is used on the regal gsx with the 7" gsx wheels
    They offered a koni/gmpp spring combo to lower the ride too
    It's up to the OP to decide if he wants to lower it. All he asked was about if he could run shorter sidewall. That's his problem if he is not lowered and does not care about wheel gap.
    Yeah you can tell hpt your tire height
  16. #56 Re: need some tire advice
    SWPA
    Even if you lowered you should still run stock height tires. Thats the point of lowering.
    And I didn't specifically point at one person for suggesting shorter tires. The members forum do it on a regular basis and its utterly ridiculous to even suggest such a thing.
  17. #57 Re: need some tire advice
    Apr 2009
    Fort Worth TX
    The OP doesn't want the large tire wall and want's to keep the stock rims due to expense. Noone suggested this. It just ended up here in the discussion.
    Did you read the entire thread? We're not morons.
    If it were my car I would run stock tires until I've saved enough cash for 18 inch rims and low pros. This is not an option for the OP at this moment.
  18. #58 Re: need some tire advice
    yes, that regal also looked stock. it was lower, hell a lot lower since springs + shorter diam tire, but it still had that nasty wheel gap.
    now if you want to run 225/50/16 or even 225/55/16, your speedo will be significantly off (esp. 50 sidewall), the car will drop even more (since diam is lower) and the wheelgap will be HUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUGE. its gonna look like a lowrider basically.
  19. #59 Re: need some tire advice
    SWPA
    Quote Originally Posted by Rico View Post
    I've been on the forum for over a year and I see smaller diameter tires suggested all the time.
    Buffalo
    Look up what a 03 gsx runs for wheels/tires
  1. 255 tire anyone?
    By aimhigh86 in forum Tires & Wheels
    Last Post: 06-08-2010, 05:15 PM
  2. Old tire fun
    By EJOUIE in forum Off Topic Discussion
    Last Post: 04-08-2010, 11:03 PM
  3. Tire Replacement
    By seeth001 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-03-2010, 11:34 AM
  4. Tire Help
    By CMURDAx in forum Tires & Wheels
    Last Post: 12-22-2009, 07:53 PM
  5. tire rack ? about this tire
    By GTPJOE90 in forum Tires & Wheels
    Last Post: 03-09-2009, 09:12 PM
