Thread: will G6 wheels fit a grand prix
Results 1 to 20 of 36
  1. #1 will G6 wheels fit a grand prix
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    the grand prix is a 115mm bolt pattern and the G6 has 110mm bolt pattern will they fit? if not can i get the hole in the G6 wheel machined to fit my car? i dont want adapters those arent safe
  2. #2 Re: will G6 wheels fit a grand prix
    Nope and nope.
    They wont work at all.
  3. #3 Re: will G6 wheels fit a grand prix
    Waukesha, WI
    well since G6s are 110 short answer no they wont work,
    if your dead set you could have the holes reemed out but since you think adaptors arent safe, that route is even worse
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  4. #4 Re: will G6 wheels fit a grand prix
    Oct 2011
    Michigan
    damn it! those 17'' five spoke g6 rims look so sick i want that look, the grand prix GXP rims cost an arm and a leg. i need 17'' rims
  5. #5 Re: will G6 wheels fit a grand prix
    Hey dude not trying to be that guy but have you tried using the search thing on the top or google? A lot of your questions have been answered and discussed about a million times already.
  6. #6 Re: will G6 wheels fit a grand prix
    Oct 2011
    Michigan
    i looked and couldnt find the answer i wanted lol so i asked here you know how it goes
  7. #7 Re: will G6 wheels fit a grand prix
    because you cant search g6 and wheels, you need to search "g6 wheels".
  8. #8 Re: will G6 wheels fit a grand prix
    and moved.
    and to add on, adapters would be worlds safer than redrilling a set of wheels for the proper bolt pattern.
  9. #9 Re: will G6 wheels fit a grand prix
    Oct 2011
    Michigan
    yeah i dont really like either option lol but thnks for the advice if it hasnt been done here it cant easily be done
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  10. #10 Re: will G6 wheels fit a grand prix
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by asite57 View Post
    You dont even want those rims anyways. There not real chrome.
    There a steel rims with a plastic chrome hub cap. My brother had those on his G6.. gaaaay
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  11. #11 Re: will G6 wheels fit a grand prix
    Oct 2011
    Michigan
    im talking about the ones off the G6 GT with the premium wheels for that package
  12. #12 Re: will G6 wheels fit a grand prix
    Houston/Baton Rouge
    Yes, I know which ones you are talking about. My brother has a GT,.
    They are not real chrome. They are steel rims with a plastic chrome cover
  13. #13 Re: will G6 wheels fit a grand prix
    Texas
    Yep about to say the same thing with them being steel wheels and a plastic cover.
    85 Corvette
    01 TA
    03 Z06
  14. #14 Re: will G6 wheels fit a grand prix
    I live here. TLSheff's Avatar
    There are other 17s and a similar 18s option that are NOT steel with the covers.... but regardless they can't be customized to work either.
    If you REALLY have to get cheap wheels that work and want 17s look into the bullits from mustangs, they are cheap and work well. Played out, but very functional. Just sayin
  15. #15 Re: will G6 wheels fit a grand prix
  16. #16 Re: will G6 wheels fit a grand prix
    Donating Users SarasotaGTP's Avatar
    Nov 2011
    Sarasota Florida
    sorry to threadjack but what adapters would I need to run the 4 G6 wheels above cuz I was dumb and bought them a while back not knowing they didn't fit but I like the look of em obviously that's why I bought them
  17. #17 Re: will G6 wheels fit a grand prix
    you need adapters to change the bolt pattern.
    most likely it will end up being like a 25mm spacer with bolt holes, nuts, and new studs on it with the correct bolt pattern. they'd essentially make your offset way too low.
    i was just saying they can be used, but i wouldnt recommend it truly.
  18. #18 Re: will G6 wheels fit a grand prix
    5x110mm to 5x115 (or 5x114.3 for mustang closeness). Not sure what thickness you would want but most likely as thin as possible so they don't stick out too much. This is where offset and backspacing measurements would come in handy *wink wink*
  19. #19 Re: will G6 wheels fit a grand prix
    you'd also most likely have to shave down your stock studs because they'll poke through too far.
    overall it's not worth the hassle.
  20. #20 Re: will G6 wheels fit a grand prix
    Nov 2011
    Sarasota Florida
    cool thx for the info guys
  1. 97 Pontiac grand Prix wheels
    By SHELLBEAR73 in forum Introductions/Noob Questions
    Last Post: 03-21-2011, 07:41 AM
  2. Will 07 GXP wheels fit 05 Grand prix GT
    By railmule in forum Tires & Wheels
    Last Post: 09-01-2010, 06:46 PM
  3. 04 grand prix in need of wheels
    By leonardo in forum Introductions/Noob Questions
    Last Post: 01-12-2010, 04:25 PM
