Found some challenger wheels with 5x115 bolt pattern. I have a 00 gtp.
depending upon the tire you may or may not have issues. realistically that offset is way too low, but the rim width might make up for it.
just be aware that you are most likely going to have rubbing issues.
its about the same, the .25" more on each side of the wheel minus the 10mm...its whatever. however, a bunch of people run an 18x8 +35mm (or in that area) without issues. either way you might be okay.
tires you throw at that might be the limiting factor. you might need to roll the fenders (def. if youre lowered).
