Thread: Tire size and rating information
Page 1 of 3 123 LastLast
Results 1 to 20 of 54
  1. #1 Tire size and rating information
    GTX Level Member webracin's Avatar
    Arkansas
    This will be an ongoing post that I will update as more people provide information.
    Please provide the information in the following format:
    225/60R16 97S
    INFORMATION
    225/60R16 97S
    The 225 is how many millimeters across the tire tread (from shoulder to shoulder)
    The 60 is how tall the sidewall is in % of the tire tread width (225 divided by 60% is 135mm tall measured from the tire bead to the shoulder)
    The R means its a Radial tire
    The 16 is your rim size in inches.
    The 97 indicates the load rating.
    Load Index Pounds Kilograms
    71 761 345
    72 783 355
    73 805 365
    74 827 375
    75 853 387
    76 882 400
    77 908 412
    78 937 425
    79 963 437
    80 992 450
    81 1019 462
    82 1047 475
    83 1074 487
    84 1102 500
    85 1135 515
    86 1168 530
    87 1201 545
    88 1235 560
    89 1279 580
    90 1323 600
    91 1356 615
    92 1389 630
    93 1433 650
    94 1477 670
    95 1521 690
    96 1565 710
    97 1609 730
    98 1653 750
    99 1709 775
    100 1764 800
    101 1819 825
    102 1874 850
    103 1929 875
    104 1984 900
    105 2039 925
    106 2094 950
    107 2149 975
    108 2205 1000
    109 2271 1030
    110 2337 1060
    And finally the S....This is the Speed rating for the tire
    M 81 mph 130 km/h
    N 87 mph 140km/h Temporary Spare Tires
    P 93 mph 150 km/h
    Q 99 mph 160 km/h Studless & Studdable Winter Tires
    R 106 mph 170 km/h H.D. Light Truck Tires
    S 112 mph 180 km/h Family Sedans & Vans
    T 118 mph 190 km/h Family Sedans & Vans
    U 124 mph 200 km/h
    H 130 mph 210 km/h Sport Sedans & Coupes
    V 149 mph 240 km/h Sport Sedans, Coupes & Sports Cars
    W 168 mph 270 km/h Exotic Sports Cars
    Y 186 mph 300 km/h Exotic Sports Cars
    Special thanks to Tire Rack as this information is pulled from their site.
    Tire sizes that will work based on Rim Size
    16 Inch Rims
    225/60R16
    235/55R16
    17 Inch Rims
    225/55R17 Stock diameter
    235/50R17 1.39% too small so its good, but not perfect
    235/55R17 2.03% too tall. Help fill out wheel wells, increased chance of rubbing.
    245/50R17 is the same diameter of the stock tire. Expensive, limited selection.
    255/45R17 Shorter than stock, but still within 3%. A fair amount of sizes available, but not recommended for wheels 7.5 in wide or narrower. (Would probably go well on mustang 17x8 wheels)
    18 Inch Rims
    245/45R18 Stock diameter.
    20 Inch Rims
    22 Inch Rims
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  2. #2 Re: Tire size and rating information
    SE Level Member morkuma's Avatar
    abbotsford, bc
    my tires are Y rated..
    i also saw here ( Falken Tire ) that there are Z rated tires.
    i have falken 452's 245/45/18 100Y
    so what does the Y get me?
    people are like slinkies, not really good for anything until you push them down some stairs
  3. #3 Re: Tire size and rating information
    Barksdale AFB, LA
    Quote Originally Posted by morkuma View Post
    186MPH sustained.
    Tire Tech Information - How to Read Speed Rating, Load Index & Service Descriptions
    2009 Subaru Impreza WRX STI
  4. #4 Re: Tire size and rating information
    abbotsford, bc
    thanks buddy!
  5. #5 Re: Tire size and rating information
    May 2008
    McHenry IL
    z rated are 200mph right? cuz i can go 200 lmao
  6. #6 Re: Tire size and rating information
    Feb 2008
    Something to add to the available tire sizes:
    245/50-17 is the same diameter of the stock tire.
    245/45-17 is a little smaller diameter, but has more size options and better pricing.
    255/45-17 is in between the above sizes, but wider. A fair amount of sizes available, but not recommended for wheels 7.5 in wide or narrower. (Would probably go well on mustang 17x8 wheels)
  7. #7 Re: Tire size and rating information
    Apr 2008
    I have 04 grand prix looking to get 245/50-20s just wanted to be sure that tire is not to big. can anybody help?
  8. #8 Re: Tire size and rating information
    Feb 2008
    245/50-20 is a bit large of a tire. That is a 29.6" diameter tire, where the factory was 26.6".
    245/35-20 would be closer to the right overall diameter.
  9. #9 Re: Tire size and rating information
    SE Level Member og512's Avatar
    Arlington Heights, IL (NW Suburb of Chicago)
    Will 255/35-20 rub on an 04+, stock height?
  10. #10 Re: Tire size and rating information
    GTX Level Member Juanmiguel's Avatar
    Mexico
    By saying that the tire size will work do you guys mean that it will not rub and also won't ge the TCS light on? I've read that if you change the diameter, the TCS light will come up.
  11. #11 Re: Tire size and rating information
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by Juanmiguel View Post
    depends on what model GP. I think the 04+ might have that problem issue but only with go a diameter thats way different then stock.
  12. #12 Re: Tire size and rating information
    May 2008
    Winnipeg, MB
    just looking on kijiji.com for rims and came across these mustang rims, I want to know if I could use them?
    2003 Mustang GT wheels MINT CONDITION - St. Albert Tires, Rims For Sale - Kijiji St. Albert
    These wheels were taken off at 15000km.they are perfect condition,17x8''5.72'' back spacing.Fits 94 and up mustang and ford rangers.$400.780 913 3843
    I have All Season Michelins MXV4 Plus 225/55R17 95H with TPMS
    Thanks
    2007 Pontiac Grand Prix
  13. #13 Re: Tire size and rating information
    Jul 2008
    sumter,south carolina
    ^ yes they will fit.
    02 GTP with mods 05 GP for DD
  14. #14 Re: Tire size and rating information
    Nov 2010
    WI
    Will I be able to fit my 1995 firebird rims with 245/50-16 tires on my 02 Grand Prix GT? The rims are 16x8 and they are also stamped 55.0....maybe that is the back spacing or off set or something?
    Thanks
  15. #15 Re: Tire size and rating information
    that is the offset, +55mm.
    also, those rims are the wrong bolt pattern so they will not fit a wbody.
  16. #16 Re: Tire size and rating information
    Donating User Odi's Avatar
    Chicago South Suburbs
    bio, you should make a sticky that says NO, FIREBIRD WHEELS WONT WORK, since thats like the most asked question ever.
  17. #17 Re: Tire size and rating information
    if people read a little bit they would know that they are way different bolt patterns.
  18. #18 Re: Tire size and rating information
    SE Level Member eightyseven's Avatar
    New York (which sucks)
    I'm putting grand am gt rims on as my winter rims. I was going to use my 16" Special Edition rims, but they look like they belong on my grandmother's buick. Plus I got a bad belt. The grand am rims are 16's, so I'll be looking for 225/60R16 tires, seen some nice michelin x tires. For summer I got 18" Metal FX rims with 235/40R18 tires, but they just look too small. What size tires would be best for my 18's? I think the tire needs to be 235/?R18?
    00 Ford Expo EB - sold
    02 WRX - sold
    01 GTP Special Edition - Rims
    69 Club Wagon - yup
  19. #19 Re: Tire size and rating information
  20. #20 Re: Tire size and rating information
    I probably sound stupid, but if the rim was on 235 tire, don't I need a new 235 tire? 245 would work on the rim?
    02 WRX - sold
    69 Club Wagon - yup
  1. tire size
    By dwm1975 in forum Tires & Wheels
    Last Post: 07-24-2008, 01:03 PM
  2. recommend tire size for 17x9 bullitt
    By nemesis in forum Tires & Wheels
    Last Post: 06-19-2008, 03:48 AM
  3. UserCP not updating information?
    By SD GTP in forum Forum Bugs/Suggestions
    Last Post: 02-18-2008, 01:44 PM
  4. 17x9 okay? what tire size?
    By Bio248 in forum Tires & Wheels
    Last Post: 02-15-2008, 02:09 AM
  5. Some interesting Eaton Information
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2008, 05:31 PM
