Thread: which rims you think?
Results 1 to 20 of 25
  1. #1 which rims you think?
    GT Level Member GP2003GT's Avatar
    Fayetteville, NY
    http://www.cardomain.com/ride/2556536 NKG Iridium Plugs, 8mm Spiro Wires, ZZP Reprogrammed PCM, ZZP 3" full cat, ZZP Ceramic Coated Ported Manifolds, ZZP HV3, ZZP HVTB, ZZP ER Ratio Rocker Arms, ZZP Drilled 180* Thermostat, MotorSports Performance Intake, Reptile's IAT and dezldave tuned
  2. #2 Re: which rims you think?
    Saraland Alabama
    number 2 gets my vote, I like the bigger spokes personally
  3. #3 Re: which rims you think?
    St. Louis Mo.
    #2 would be my choice as well.
    But then again I am a little biased
    My TSW Mondello's
    One thing I will point out to you is this.....Be sure to use Gorilla Lug/Tuner bolts to secure your wheels. Anything else will fit to tight inside the cavity to reach the bolt and will nick the hell out of your rim. Trust me. I found out the hard way
    James Shafer
    St. Louis MO
  4. #4 Re: which rims you think?
  5. #5 Re: which rims you think?
    Fayetteville, NY
    ok...lol i see which ones i am picking then...so the bolts that come with it will cause you to damage your rims?
  6. #6 Re: which rims you think?
    St. Louis Mo.
    Quote Originally Posted by GP2003GT View Post
    Well I should kind of correct myself here. Its not the "bolts" but actually the nuts that go over the bolts inside the rim. The set that sold with my set of rims was to thick, and when placing the 4 way into the hole to undo the nuts, the 4 way outter part would rub continually against the paint inside the resessed holes that containt the lugs and bolts.
    I had purchase these Gorillas Lugs that are thinner in diameter and the adaptor tool is thin as well so there is no hitting the inside of the rim. I will try and snap a few shots tomorrow to show ya what I am trying to say. Hopefully it will clear it up for ya
    James Shafer
    St. Louis MO
  7. #7 Re: which rims you think?
    Fayetteville, NY
    ok thanks
  8. #8 Re: which rims you think?
    Saraland Alabama
    Quote Originally Posted by GeddyLee View Post
    sounds like a spline drive type thing?
  9. #9 Re: which rims you think?
    St. Louis Mo.
    Sorry for the delay in getting these photos done. I have had this stupid summer cold and its been kickin my arse!
    Here are the shots, sorry for some of them being blurry, but camera's batteries decided to shoot craps when I was wrappin things up. But you will see what I am talking about in regards to the tight fit.
    Here you can see the rub marks from the 4 way when put into the lug hole.
    Here you can see how tight the 4 way sits against the lug hole. I had to use masking tape to try and help reduce any wear on the inside.
    Now here is the picture of the Gorillia Lug adapter that fits over the Gorillia lugs attached to the bolts. You can plainly see the clearance difference between using the 4 way and the Gorillia adapter.
    I hope those pictures helped to make it a little clearer for you? You can buy the Gorillia Lugs at most good rim shops or off the internet.
    James Shafer
    St. Louis MO
  10. #10 Re: which rims you think?
    the TSW's hands down!
  11. #11 Re: which rims you think?
    Fayetteville, NY
    ok yeah wow i see now i meant to say lugs not bolts...lol...so how did you get these lugs and the key?
  12. #12 Re: which rims you think?
    Number 2 for sure.
  13. #13 Re: which rims you think?
    Fayetteville, NY
    lol yeah im pretty sure number 2 is the one
  14. #14 Re: which rims you think?
    St. Louis Mo.
    You can get them from any local good tire/wheel dealer. Or off the internet. You just need to look for Gorillia Lugs. I cant remember the demisions off the top of my head, I am still at work till 6am and I can check later on Saturday for ya.
    James Shafer
    St. Louis MO
  15. #15 Re: which rims you think?
    May 2008
    LITH Illinois
  16. #16 Re: which rims you think?
    Fayetteville, NY
    looks like number 2 is crushing the competition
  17. #17 Re: which rims you think?
    SE Level Member Orbital431's Avatar
    Albuquerque, NM
    I would say #1 if it didn't have that chrome. #2 all the way.
    And i'll have to learn from that too Geddy. Srry to hear bout ur wheelz. :'(
  18. #18 Re: which rims you think?
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    TSW's.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  19. #19 Re: which rims you think?
    Apr 2008
    Chillin at the Beach , VA
    #2 for sure.
  20. #20 Re: which rims you think?
    GT Level Member DesQ27's Avatar
    May 2008
    Kennewick
    I feel pointless...but I'm saying it anyways....Number 2.
    More of a bold american car look, more impressive looking
    "True measure of a man's strength is his self control in time of great stress" - ME
    2002 GTP: U-Bend and Resonator Delete; Mufflers Modded; K&N Short Ram Air; WS6 Ram Air Hood
  1. GTO rims
    By rocket69GTP in forum Visual/Body Modifications
    Last Post: 05-19-2008, 01:51 AM
  2. Rims(56K beware)
    By Mikel2k7 in forum Visual/Body Modifications
    Last Post: 03-05-2008, 05:58 PM
  3. Rims
    By GP2003GT in forum Tires & Wheels
    Last Post: 02-21-2008, 10:11 PM
  4. rims chop please??
    By nemesis in forum Visual/Body Modifications
    Last Post: 01-15-2008, 03:38 PM
