Thread: is it ok to mix tire size?
Results 1 to 9 of 9
  1. #1 is it ok to mix tire size?
    chicago
    i pick up these (2) dunlop for $140. they're brand new. my question is, it's going to be little hard trying to find another used set with same brand name to match up. will it be ok if i get another 2 different size 18? i'm going to put 255/45 up front and maybe 245/45/18 on the back? this just going to be temperary until i can afford 2 new 255/45.
  2. #2 Re: is it ok to mix tire size?
    Banned
    Wichita Falls, Texas
    Why don't you just go and buy two more of those somewhere else..?
  3. #3 Re: is it ok to mix tire size?
    chicago
    cause they like $200 something a piece
  4. #4 Re: is it ok to mix tire size?
    Banned
    Eh, buy some used ones or something.
    255 45 18 dunlop sp sport 9000 items on eBay.com
  5. #5 Re: is it ok to mix tire size?
    chicago
    i don't trust ebay. thanks for the link tho. i'm going to check with tire shop tomorrow. i got the dunlop on craigslist. hopefully someone out there selling a set.
  6. #6 Re: is it ok to mix tire size?
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    In addition to being wider, the 255's will have a slightly larger diameter than the 245's. I know having different sizes on the same axle will screw up both traction control and ABS, but I think you should be fine as long as you keep both fronts and both rears the same.
    Our cars already tend to sag in the rear, and putting the larger tires in the front will only amplify this effect.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  7. #7 Re: is it ok to mix tire size?
    chicago
    cool thanks for the info! i don't have to worry about mixing different size now cause i bought all four same size.
  8. #8 Re: is it ok to mix tire size?
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    just a note--- i read your pic thread... (looks sweet, btw) even though you bought 2 more of the same size tire, since you bought 2 diff. mfg's they really wont be the same size, (they'll be pretty close, but i've seen almost an 1/8" inch different in overall height between mfg's... so i'd run the mismatched pair in the rear until you can get 2 matching...
  9. #9 Re: is it ok to mix tire size?
    chicago
    thanks, actually i got 3 matching tires and i different manufacture brand. the 2 new one are up front and the other used are on the back. i'm going to do less of a driving on the car for now cause i think it might need alignment.
  1. Tire size and rating information
    By webracin in forum Tires & Wheels
    Last Post: 03-01-2018, 11:18 PM
  2. tire size
    By dwm1975 in forum Tires & Wheels
    Last Post: 07-24-2008, 01:03 PM
  3. recommend tire size for 17x9 bullitt
    By nemesis in forum Tires & Wheels
    Last Post: 06-19-2008, 03:48 AM
  4. yet another tire question
    By Wadeb79 in forum Tires & Wheels
    Last Post: 06-03-2008, 06:59 PM
  5. 17x9 okay? what tire size?
    By Bio248 in forum Tires & Wheels
    Last Post: 02-15-2008, 02:09 AM
