Thread: Gxp rear tires
Results 1 to 20 of 21
  1. #1 Gxp rear tires
    pa
    i own a 06 gxp the rear tire size is 225/50-18 , kinda hard to find . so i wonder if i could go with 225/45-18 ? any suggestions will they fit?
  2. #2 Re: Gxp rear tires
    theyre gonna be smaller than stock and increase your wheel gap. id suggest going taller rather than shorter.
  3. #3 Re: Gxp rear tires
    West Side Michigan
    225-50-18 is a very common tire.. comes stock on a lot of oem vehicles.. If you want the 45 aspect ratio you'll need a wider tire. I'd suggest a 245-45-18 to replace your 225-50-18.
  4. #4 Re: Gxp rear tires
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    Quote Originally Posted by warren13 View Post
    Go wider, not smaller on the back.
    You won't regret it
  5. #5 Re: Gxp rear tires
    pa
    any suggestions how wide i can go?
  6. #6 Re: Gxp rear tires
    the rear wheels are 18x7, correct?
    means you can easily get away with a 235 or 245 wide tire.
  7. #7 Re: Gxp rear tires
    Jun 2010
    Illinois.
    Yes they are and very easy.
    On the new wheels I'm running, I'm at 255. With a little bit of rub in the back when flying around a corner with a person in the back seat.
  8. #8 Re: Gxp rear tires
    pa
    cool
  9. #9 Re: Gxp rear tires
    pa
    i ended up using 235 50 18 and that was kinda tight, but they fit.
  10. #10 Re: Gxp rear tires
    GT Level Member VDV18's Avatar
    Wishin I was at the Dunes
    What do you mean it was kind of tight?
    2006 Black GXP
    2006 Yamaha Raptor 700R - LRD Pro R4 Racing Pipe
  11. #11 Re: Gxp rear tires
    pa
    it was a tight fit. not alot room for anything much bigger
  12. #12 Re: Gxp rear tires
    West Side Michigan
    That's what she said
  13. #13 Re: Gxp rear tires
  14. #14 Re: Gxp rear tires
    Jun 2010
    Illinois.
    you could easily fit 245s.
    Listen to Nick, this ****ing guy knows what hes talking about. lol
    Even without ever owning an 04+? Impressive.
  15. #15 Re: Gxp rear tires
    Donating User Odi's Avatar
    Chicago South Suburbs
    There are people running 265's on 04+...
  16. #16 Re: Gxp rear tires
    Do you mean you don't think a larger tire would fit on your rim? Or do you mean a larger tire wouldn't fit in the wheel well?
    And are you talking about the 7" rim?
    I'm confused.
    2006 Black GXP
  17. #17 Re: Gxp rear tires
    im assuming he is talking about the tire height considering he is running a taller tire than stock. however if he would have stayed with the stock overall diameter and gone with a wider tire he could have fit a much wider tire.
  18. #18 Re: Gxp rear tires
    pa
    i was considering that option , but the 245 was has a smaller diameter than the stock tires, and there was good chance they wouldnt have passed a PA. state inspection. in PA. you can go up , but not down.
  19. #19 Re: Gxp rear tires
    Jun 2010
    Illinois.
    Quote Originally Posted by MiriV View Post
    Eh. I think there would be some issues there without hardcore fender rolling. Go 245 and you will be safe, or you could push it like me with 255's, I think even with that I'm gonna eventually need fender rolling.
  20. #20 Re: Gxp rear tires
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    not on a 7" wide rim..
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  1. new tires are on!
    By boosting98 in forum Tires & Wheels
    Last Post: 09-30-2010, 11:17 PM
  2. will my tires fit?
    By JESSEGOTTA GP GT in forum Tires & Wheels
    Last Post: 08-14-2010, 11:06 PM
  3. Replace 15" tires with 16" tires
    By maxim08 in forum Tires & Wheels
    Last Post: 10-24-2009, 06:44 PM
  4. new pics!! new rim/tires/rear led lights.
    By tmackster in forum Visual/Body Modifications
    Last Post: 10-18-2009, 12:25 AM
