Thread: People with 20's
Results 1 to 16 of 16
  1. #1 People with 20's
    GT Level Member stevenk8's Avatar
    Macomb MI
    When I first got my gp it had a set of 20's. The tire size was 245/35/20 but they stuck out so far from my car. Im looking into getting a new set of 20s but would like to see pictures of cars with 20s to see how far they stuck out. The rims must have been 20x9 or 20x10s. But after that I hated 20's for this reason. So does anyone have pictures of 20's on a car that are the right size for a gp
    thanks
    2002 grand prix gt (CAI,180*tstat,MSD wires,magnaflow high flow cat,ubend delete,18in wheels,HID headlights and fog lights)
    More mods soon to come!
  2. #2 Re: People with 20's
    sticking out has to do with the offset of the wheels. youre gonna want to run a 20x8.5 +40mm or so.
  3. #3 Re: People with 20's
    Jul 2008
    sumter,south carolina
    heres an album with assorted angles and ****..
    gtp pictures by jmc803 - Photobucket
    02 GTP with mods 05 GP for DD
  4. #4 Re: People with 20's
    GT Level Member Louie3's Avatar
    Laguna Vista
    http://www.grandprixforums.net/final...s-2-37472.html
    mine are 20x8 on 245/35 tires offset must be right cause their pretty flush
    ZZP PCM, Wbody PCM, Custom PCM ( the best ), Headers, 3" exhaust, 3.4" pulley, ZZP 10.3 Wires, AL 104's, 160 tstat, 1.9 Rockers, Custom huge cone intake. Gunna push this GTP to the limit.
  5. #5 Re: People with 20's
    SE Level Member 2fnlow2's Avatar
    Sidney, Ohio
    mine stick out as well, just a tick outta the wheel well but only by a hair. The offset isnt correct on em tho so thats the problem. Wheels came off a caddy so their offset was different
  6. #6 Re: People with 20's
    GTP Level Member
    springfield IL
    your gona have to get an offset wheel... i had 22's platinum shields with 30series tire.. didnt poke out at all! did rub at times. :-<
  7. #7 Re: People with 20's
    Aug 2008
    KCMO
  8. #8 Re: People with 20's
    Kansas
    I have a bunch somewhere
    SOLD 1999 GT Silvermist TS
  9. #9 Re: People with 20's
    Sidney, Ohio
    Quote Originally Posted by tc300 View Post
    You got pics? Im wanting to upgrade to 22's on the grand prix but hear diff things about it. How bad did they rub?
  10. #10 Re: People with 20's
    its all about the wheel width, offset, and tire size you run. if you stay at the same overall stock diameter as the stock tires then you'll be much better off then trying to stuff something bigger into the fenders. however, the bigger you go, the more expensive it is to go to a lower profile and a lot of people arent ready to pay for that expense.
    what wheel are you trying to run, with what tire?
  11. #11 Re: People with 20's
    Sidney, Ohio
    I wanna run a 22, heard you hafta run with a 25 series tire tho and nothing bigger
  12. #12 Re: People with 20's
    depends on the width of the tire.
    which depends on the width of the wheel.
    which depends on offset and how low you want to go.
  13. #13 Re: People with 20's
  14. #14 Re: People with 20's
    Sidney, Ohio
    with doin a 22 i will prolly hafta get a 10" wide rim. havent really checked into exactly what I want yet so not quite sure 100% on specifics, just wanted a general suggestion/info. I plan to bag the car but im sure I would roll around on em stock height for a bit.
  15. #15 Re: People with 20's
    its also gonna have a lot to do with your willingness to run a little negative camber to clear the fenders or not. you can run a lot wider wheels when you start stretching tires and running negative camber.
    however, i would assume with a 22x10 wheel youd need to be in the +40mm offset area. let's think this over: the stock wheel is +52mm, 6.5" wide. so with a 10" wide wheel that is +40mm youre gonna be 12mm + 1.75" closer to the fender and 1.75" - 12mm closer to the strut. can you manage that? if you get what im trying to explain, is take some measurements and see what you can actually clear safely.
  16. #16 Re: People with 20's
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by 2fnlow2 View Post
    Not true. Theres many many 22s in a 9" width
    your going to have to go with some 25 series tires.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  1. Nc/sc people. Wtf
    By JESSEGOTTA GP GT in forum Southeast
    Last Post: 05-15-2010, 12:54 PM
  2. Just a little something for us GM people
    By BADAZGTP in forum Off Topic Discussion
    Last Post: 02-24-2010, 04:57 PM
  3. Some people.....
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 02-07-2010, 07:27 PM
  4. People Who..
    By KawaFord in forum The Rant Forum
    Last Post: 01-07-2010, 02:08 PM
  5. Hello people!
    By bobbyd in forum Introductions/Noob Questions
    Last Post: 03-14-2009, 11:47 AM
