Thread: Will they fit?
Results 1 to 12 of 12
  1. #1 Will they fit?
    Iowa
    I recently acquired a set of 4 18" tires. They look to be too big for my car but Im hoping they will fit or only require a small amount of work to make them fit. My ride is a 2007 Grand Prix Base
    Here is the info off of the tires:
    P235/55 R18 99T
    Thanks for the help.
  2. #2 Re: Will they fit?
  3. #3 Re: Will they fit?
    Iowa
    Thanks, I forgot to add that they are off a 2010 Chevy Equinox so that explains the height...
  4. #4 Re: Will they fit?
    Charles City, IA
    dont think they will.
    SMGPFC Two Nipple General
  5. #5 Re: Will they fit?
    Aug 2008
    KCMO
    just tires or tire and wheels?
  6. #6 Re: Will they fit?
  7. #7 Re: Will they fit?
    canada
    base size for ur vehicle is 16 so an 18 TIRE will not fit, now if you are meaning that you have the WHEELS (metal, or aluminum part etc) and TIRE as a combo then all you need to know is the ofset and bolt patern of the WHEEL to know if it will fit the car. if you presently have 18's on the car then tires should prolly fit
  8. #8 Re: Will they fit?
    West Side Michigan
    Bolt pattern on a 2010 Chevy Equinox is 5x120mm
    Our cars take 5x115mm... so those rims will NOT fit.
  9. #9 Re: Will they fit?
    Iowa
    I went ahead and just put them on to see if they fit, they bolted on just fine, but the tires are too tall like someone said. The rear wheels rub slightly on the suspension.
    Looks like I will need to purchase a different set of tires
    I took some pictures of the rims and tires on the car and the part that rubs if anyone is interested. I uploaded them here: GP pictures by aevolt - Photobucket
  10. #10 Re: Will they fit?
    Aug 2008
    KCMO
    not to be and asshole but those things are nasty
  11. #11 Re: Will they fit?
    ^that. how are those from an equinox w/ a pontiac center cap?
  12. #12 Re: Will they fit?
    Apr 2009
    Maine
    I didn't think those were pictures of a GP for a sec. Because of the wheels, I thought I was looking at a Chrysler Sebring or something.
