Thread: Check Tire Press Light
Results 1 to 7 of 7
  1. #1 Check Tire Press Light
    SE Level Member corsagtp's Avatar
    Calgary, AB
    Why does the DIC have a check tire press light if my car doesn't have band sensors or valve stem sensors? How would the car know if the tire pressure is low?
    97 GTP - POS parked in backyard
    07 Saab 9-3 2.0 turbo 6-speed - Awesome
  2. #2 Re: Check Tire Press
    GT Level Member VDV18's Avatar
    Wishin I was at the Dunes
    Revolutions of the tire I think. My 06 GXP does this, but I think the 07 and 08's have TPS.
    2006 Black GXP
    2006 Yamaha Raptor 700R - LRD Pro R4 Racing Pipe
  3. #3 Re: Check Tire Press Light
    GTP Level Member
    Pittsburgh
    the car uses the wheel speed sensors to determine if the tire pressures are different or if one has a drastic change in revolutions ( like a tire that is loosing air)
    the Tire Pressure system works, as i have the same system on the Bonneville as the GP and it has alerted me of a tire loosing air (big screw thru the tread) before i felt anything was wrong or had the tire completely flat. I was able to make it to a safe place and put a tire plug in the tread
    2003 SSEi,
  4. #4 Re: Check Tire Press Light
    Calgary, AB
    so if you buy aftermarket rims and tires that are different then the stock will the tpms become ineffective?
  5. #5 Re: Check Tire Press Light
    GTP Level Member
    Pittsburgh
    depends what car your talking about. If you have the Wheel speed sensor TPMS then it dosent matter, the Wheel Speed Sensors look at each other to determine tire pressure. The system still works If you have the Valve stem mounted Sensors then you need to get new sensors installed in the wheels
    2003 SSEi,
  6. #6 Re: Check Tire Press Light
    Calgary, AB
    I see, makes sense now
  7. #7 Re: Check Tire Press Light
    West Side Michigan
    I wonder if the system works for other years? I know that the Tire pressure sensor in the DIC came only on the 97's. I wonder if the system is still there to get it to work somehow?
  1. ABS Light+Low Trac+Check Tire Pressure Problem
    By 1997gpgt in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2011, 10:18 PM
  2. TCS light and check tire on 97 GTP won't go out
    By alkygto in forum General Tech Discussion
    Last Post: 04-22-2010, 06:27 PM
  3. Check Tire Pressure?
    By 04gpking85 in forum General Tech Discussion
    Last Post: 02-11-2009, 01:06 PM
  4. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  5. ABS and Check Tire Pressure with hard steering
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 04-09-2008, 04:32 PM
