Thread: Factory gxp wheel / tire questions
Results 1 to 5 of 5
  1. #1 Factory gxp wheel / tire questions
    SE Level Member funkenmiester's Avatar
    LORAIN
    Hello,
    I have a 2006 GXP. As everyone knows, the tires are unidirectional, and the rims are bigger in the front than in the back, with different offsets to top it all off. This makes tire rotation impossible.
    I need new tires and obviously would like to try to get them to last as long as I can. Has anyone experimented with swapping the rims from front to back and vise versa? I will also most likely abandon the unidirectional issue with the new tires.
    Any feedback will be appreciated.
  2. #2 Re: Factory gxp wheel / tire questions
    SE Level Member slow94formula's Avatar
    MN
    I saw one the other day that was OBVIOUSLY swapped from front to back. looked like ass. It even made the car look like it needed an alignment BAD! Do not do it. If you don't get directional tires then you could at least swap from side to side, But it is like any performance car. One set of tires stays on the car and just rolls, and the other set gets used and replaced, used and replaced, etc.
  3. #3 Re: Factory gxp wheel / tire questions
    you can swap front to back all you want. it wont matter. it just looks funny. if i were you i would try to find another set of two of the wheel you want to keep (id suggest the lower offset, wider ones) and run all four of the same.
  4. #4 Re: Factory gxp wheel / tire questions
    GT Level Member VDV18's Avatar
    Wishin I was at the Dunes
    I ditched the 7 inch rims and bought 2 more 8 inch rims and run 255/45/18's all around. It looks fantasitc compared to the worthless looking 7 inch rims in the rear.
    Do it, you'll thank me later. You'll be able to rotate whichever way you want then.
    2006 Black GXP
    2006 Yamaha Raptor 700R - LRD Pro R4 Racing Pipe
  5. #5 Re: Factory gxp wheel / tire questions
    LORAIN
    Anyone got any 8" rims for sale? LOL!
  1. Wheel and Tire question
    By zerolimitsgt in forum Tires & Wheels
    Last Post: 03-17-2010, 03:50 PM
  2. 04+ factory stereo in 03 GT w/steering wheel controls
    By Teancum in forum Audio, Security & Visual Electronics
    Last Post: 01-28-2010, 04:27 PM
  3. Lakeshore Wheel & Tire?
    By Sheepdog in forum General Tech Discussion
    Last Post: 08-04-2009, 01:13 AM
  4. Factory wheel question
    By s10mods in forum Tires & Wheels
    Last Post: 08-23-2008, 06:57 AM
