Thread: 18 or 20s?
Results 1 to 17 of 17
  1. #1 18 or 20s?
    SE Level Member rambo33's Avatar
    Illinois
    what do you guys think? 18 inch saleens or 20s? and if you have 20 inch saleen rims can you post a picture?
    Pontiac windshield banner decal, Grand Prix Mud Flaps, Grand Prix caliper overlay, trunk debadged, clear corners, sd air dam, fig polished grilles, rear bumper pontiac inlay....much more to come
  2. #2 Re: 18 or 20s?
    Norristown, PA
    Since you have a 97-03, I say 18".
  3. #3 Re: 18 or 20s?
    20s look better.
    however, have you looked into the sizing on the wheels youre looking at? in any form, saleens are going to be a very big wheel for you to run correctly. you will probably need to finesse your fenders to fit them well.
  4. #4 Re: 18 or 20s?
    SE Level Member e6600's Avatar
    Los Angeles
    id say 18" too
    20s will wear on your tranny a bit
    98 grand prix gtp: stock until i fix problems
  5. #5 Re: 18 or 20s?
    Illinois
    Well they are 18 by 9 and 20 by 9 so I thought the 20s would fit fine? O and the offset is 36 I believe on both if that helps
  6. #6 Re: 18 or 20s?
  7. #7 Re: 18 or 20s?
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    no ones got 20" saleens. and with the way those rims look. I would get 18s, they are already look bigger then they are..
    20s would look pimp though.. haha. You lowerd?
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  8. #8 Re: 18 or 20s?
    Troy OH
    ^^^those are 18's?
    in that case... i vote 18's lol. lower it to get rid of some wheel gap and you've got a really clean looking car
  9. #9 Re: 18 or 20s?
    Donating User Odi's Avatar
    Chicago South Suburbs
    get 18's, those rims are damn heavy. also, dont get any offset under 36 on those unless you plan on doing some fender work.
  10. #10 Re: 18 or 20s?
    Houston/Baton Rouge
    Quote Originally Posted by Poil336 View Post
    ^^^those are 18's?
    Yup,,,
  11. #11 Re: 18 or 20s?
    Illinois
    Well those 18s look awesome but no I'm not lowered. It's on the list. If 20s are goin 2 create a problem then I can settle with 18s
  12. #12 Re: 18 or 20s?
    not a baller unless you get 20"+, you should know that by now.
  13. #13 Re: 18 or 20s?
    GTX Level Member real diehl's Avatar
    Salina, KS
    Don't forget the chrome badges...
    ??" <----(translates to 22")
    signature removed for inappropriate content.
    -bio
  14. #14 Re: 18 or 20s?
    SE Level Member buford1972's Avatar
    Apr 2009
    Peoria, Arizona
    The "load" that the transmission see's due to the weight difference between a stock 16" wheels weight and say an 18" or a 20" rim is negligible. It is much harder on a transmission doing burnouts especially when you have good traction. As our cars are reaching up to and well beyond 100K miles, and there is a lack of people who actually perform preventive maintenance on thier cars. A transmission problem may seem like it was caused by a change in wheel size and weight. And a mechanic at a transmission shop may conferm this, but the reality is that it wont make any difference. Change your fluid and filter regularly, and if your worried about the weight of a tire/rim combo then shell out the coin for Forged wheels whch are twice as strong and twice as light as a cast wheel. They are also about 1 1/2 times more in price. I agree with Bio248. 20" rims are the perfect combo of a large size rim and a good profile tire for our cars.
    Comp Cams Cam. #150 springs. roller rockers. CNC heads. 3.4" pulley. P&P Gen V. 8-rib w/belt wrap. N* & LQ4. 1" phenolic spacer. P&P/coated LIM. boost temp gauge. Aeromotive fuel rails. underdrive W/P pulley. coated TOG headers. Magnaflow cat back. Random Tech DP & Cat. balance shaft delete. built trans. Hughes converter.
  15. #15 Re: 18 or 20s?
    Jan 2009
    Tallahassee, FL
    18s, almost anything bigger than that just looks bad to me
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  16. #16 Re: 18 or 20s?
    GT Level Member Davisgtp's Avatar
    Dec 2008
    Rockford, Illinois, United States
    20's any day
    Thrasher Intake, Intense 3.4 pully with other mods, DHP PCM, u bend delete, 20" Kmc Wheels with Nitto Neo Gen Tires
  17. #17 Re: 18 or 20s?
    MA
    18s on a 97-03
    20s on an 04+
    SMGPFC Member #9
20s
