Thread: Tire fitment question
Results 1 to 5 of 5
  1. #1 Tire fitment question
    Helena, MT
    Ok, so I have 17 x 8 rims with a +45 offset and I'm looking for my next set of tires. I currently have 235-55-17 on them and it's a little tall but works pretty well. What I'm wondering is if I'll have any problems running 255-45-17s instead. I know they'll fit fine on the rim, but does anyone know if they'll rub anywhere? Has anyone run that size tire before?
    Other info that might matter, lowest I'm going to drop the car is Vogtland springs (about an inch)
    Any help would be great. Thanks
  2. #2 Re: Tire fitment question
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    not sure, but you might need to go with 245-45/17
    Any good tire shop will be able to look up the size and compare them, I think our stock tire hight is like 26.1 inches, if I remember...
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  3. #3 Re: Tire fitment question
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    factory height with a 225/60/16 is 26.62, and the 255/45/17 is 26.03 so it should even out cause your putin them on a 8 inch wide wheel means it will be a lil taller closer to factory and the 26.03 is on a 10inch wide wheel and on the 8inch should be around 26.60 so it should work out really good
  4. #4 Re: Tire fitment question
    Helena, MT
    Thanks for the info guys. Still, can anyone on this here forum say this is the size tire they are running?
  5. #5 Re: Tire fitment question
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    They should be fine man. Thats a half inch shorter then stock. Thats going give you plenty of rim when lowerd.
    post pics when you get them on.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  1. Wheel Fitment Question
    By CMURDAx in forum Tires & Wheels
    Last Post: 02-22-2010, 03:59 PM
  2. Tire Question
    By Kenny75k in forum Tires & Wheels
    Last Post: 09-10-2009, 09:13 PM
  3. Tire question
    By boosted475 in forum Tires & Wheels
    Last Post: 08-21-2009, 02:18 PM
  4. Yet another tire question...
    By xbnb1978x in forum Tires & Wheels
    Last Post: 08-06-2008, 05:19 AM
  5. yet another tire question
    By Wadeb79 in forum Tires & Wheels
    Last Post: 06-03-2008, 06:59 PM
