Thread: tires other than 245/35/20
Results 1 to 14 of 14
  1. #1 tires other than 245/35/20
    SE Level Member Cbierniat24's Avatar
    Mi
    Im looking for some new tires for my twankies and I was wondering if any has experienced with different sizes other than 245/35/20? I am looking for a little bit bigger sidewall because the potholes out here in Michigan are horrible. Theres a guy who has some 245/50s... would that set off TCS light or do any other harm? Not too familiar with tires so please help me out!
    could I go any bigger?
    255/35 rear
    245/35 front
    I got a good deal on the 255s thats why I got em.
  2. #2 Re: tires other than 245/35/20
    why did you put the big tires on the rear on a FWD car?
    245/50/20 is way too big. you might get away with 245/40/20.
  3. #3 Re: tires other than 245/35/20
    Mi
    I know its a fwd but the tires rub up front as it is when i turn all the way with the 245s...
  4. #4 Re: tires other than 245/35/20
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    the 255/35/20's is not a good idea for the front because most likely you're rubbing because they're too wide and the 255s are even wider, but they should work on the back. that tire will be only a quarter inch bigger in diameter than the 245/35/20's you currently have on. Unfortunately there isnt really a good tire size to put on 20in rims for the front of our cars.
    245/50 wont fit on the car. period.
    235/40 would give you the best clearance (closest to stock wheel and tire combo), the sidewall would be bigger than the 245/35s, and it would be a little bit skinnier tire which might be an issue if your rims are really wide. if you cant fit the 235/40s then go with the 245/40s but they'll rub worse than the 245/35s so be careful.
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  5. #5 Re: tires other than 245/35/20
    GT Level Member Davisgtp's Avatar
    Dec 2008
    Rockford, Illinois, United States
    i would not go bigger then a 45
    Thrasher Intake, Intense 3.4 pully with other mods, DHP PCM, u bend delete, 20" Kmc Wheels with Nitto Neo Gen Tires
  6. #6 Re: tires other than 245/35/20
    iowa
    has anyone actually tried a 255/35/20 on a 04+ with 8.5" rim? I am looking for a little more rubber for my comp G.
  7. #7 Re: tires other than 245/35/20
    Quote Originally Posted by tbcustomz View Post
    depends on the offset of the wheel in question.
  8. #8 Re: tires other than 245/35/20
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    that should be fine. 04+ have bigger fender wells then the 97-03s
  9. #9 Re: tires other than 245/35/20
    iowa
    Thanks for the responses. I dont know the offset of the rims. I will have to check on that. What offset would be ideal? I can actually get the 255's cheaper than the 245's. How much difference will it make with the speedo?
  10. #10 Re: tires other than 245/35/20
    for 20s with 8.5" wide wheel, youre going to want in the area of +35mm to +40mm.
  11. #11 Re: tires other than 245/35/20
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    you would never get a 35mm to clear a w-body.
    mine are +40 and the fenders lips had to be rolled completely flat
    a +45 would be the most logical.
    also a 255/35/20 just clear the spring perch on the struts (height wise)
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  12. #12 Re: tires other than 245/35/20
    Houston/Baton Rouge
    Quote Originally Posted by kuntzie View Post
    well, if your on bags yeah.lol
    but on stock height and lowering springs. +35 is fine.
  13. #13 Re: tires other than 245/35/20
    Quote Originally Posted by Ridin ON Chrome View Post
    this.
    id agree that you need a higher offset because you need to tuck yours. however, im more risque and id use negative camber to my advantage instead of just running the 'right' offset.
  14. #14 Re: tires other than 245/35/20
    Feb 2010
    my tires stick out like 1.9" more then stock.. i do have camer to compensate, at ride height i am at just -1 degree of camber though which is perfect/
    and yes, i do have big enough brakes to fill for these rims
    (13 front, 12 rear)
  1. Will these tires fit?
    By gahris in forum Tires & Wheels
    Last Post: 11-18-2009, 10:19 AM
  2. Replace 15" tires with 16" tires
    By maxim08 in forum Tires & Wheels
    Last Post: 10-24-2009, 06:44 PM
  3. New tires, what PSI ?
    Last Post: 05-10-2009, 09:36 AM
  4. Need tires for 08 GXP
    By Bigdog8080 in forum Tires & Wheels
    Last Post: 11-28-2008, 12:24 PM
