Thread: Opinion on Wheels
Results 1 to 12 of 12
  1. #1 Opinion on Wheels
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    Polish Mustang Wheels 18x9 fit Saleen, Cobra Replicarim : eBay Motors (item 120542220024 end time Mar-16-10 20:33:35 PDT)
    These wheels with 235/45/18 tires should fit diameter wise. Will the extra offset mean I'll have to roll my fenders? What do you guys think of the look?
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  2. #2 Re: Opinion on Wheels
    youre gonna be pushing it with that offset. youll for sure have to roll your fenders, but even that might not be enough.
    for 18x9 youll want to stick with the +36mm offset.
  3. #3 Re: Opinion on Wheels
    SE Level Member grandprix85's Avatar
    Milwaukee, WI
    Im feeling those rims. If I had the extra money I would buy them. 5 spoke chrome rims are the best IMO. They would go good with my black GP
  4. #4 Re: Opinion on Wheels
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    235 tire will not fit on those rims unless you like the stretched look.
    245 is minimum, 275 is recommended.
  5. #5 Re: Opinion on Wheels
    Willoughby, Ohio
    if they will fit, they would look goooood
  6. #6 Re: Opinion on Wheels
    SE Level Member zerolimitsgt's Avatar
    Apr 2009
    Cortland, Ohio
    Those wheels as long as you're not lowered too much and you roll your fenders. I'm looking at a set of 18x9 FR500s with a +24mm offset and either 255/40s or 255/35s I'm not sure which yet. Probly gunna go with the 35s so I have a little more room. The +24mm offset and the 255s will stick out 1.7 inches further than your stock tires do. Here's a couple links to help you out.
    Wheel / tire size calculator / comparer - WWW.RIMSNTIRES.COM
    Tire Size Calculator - tire & wheel plus sizing
  7. #7 Re: Opinion on Wheels
    Donating User Odi's Avatar
    Chicago South Suburbs
    Quote Originally Posted by Ridin ON Chrome View Post
    275 youre going to be rubbing like crazy. 255 is MAX, and not on that low offset.
  8. #8 Re: Opinion on Wheels
    Quote Originally Posted by MiriV View Post
    RoC is better with wheels than i am. he is the original from clubgp, i just took over his job on this side.
  9. #9 Re: Opinion on Wheels
    Houston/Baton Rouge
    If you were slammed probably so. At stock height its fine with a good set of struts and springs.
    A guy on clubgp has 275/40/18s on his GP and was fine until he put new ones on. More rubber on tires and ofcourse rubbed on the rear fenders, but only when he went fast over railroad tracks(yeah who does that,lol)..
    So 275 is the correct size for those rims, I know some might have problems if lowerd but it has been done. I just think 245s are too narrow for a 9" wide rim. 255s is better.. Even a 265/40 would be great. Not cheap but atleast it would fit the rim a little better.
  10. #10 Re: Opinion on Wheels
    well hes on eibachs so i doubt he wouldnt rub like a mofo.
  11. #11 Re: Opinion on Wheels
    Houston/Baton Rouge
    275/40s are the same diameter as stock, but that low of a offset could hit the fenders if he doesn't roll them.
    Jason runs 20x10 with 285/30 on the front 20x8 with 255/30 on the rear
    and doesnt have problems.
  12. #12 Re: Opinion on Wheels
    Willoughby, Ohio
    ^^^i love how this car looks
  1. Opinion on wheels.
    By Perry125 in forum Tires & Wheels
    Last Post: 01-28-2010, 08:45 PM
  2. HUD opinion
    By racecardude310 in forum Off Topic Discussion
    Last Post: 01-12-2010, 09:25 PM
  3. Opinion on wheels
    By Skrud in forum Tires & Wheels
    Last Post: 09-17-2009, 11:45 PM
  4. Ok, 2 more wheels for an opinion...
    By BlownBigBlock in forum Tires & Wheels
    Last Post: 06-12-2009, 02:11 AM
  5. Opinion on wheels on the 95 gtp?
    By 95gtp in forum Tires & Wheels
    Last Post: 02-23-2009, 05:48 PM
