i would do the same size all around, but thats me.
i would too especially on a FWD car
Bumpin up instead of starting a new thread:
anybody have pics of the saleen wheels with the +36mm offset on an 18X9 rim? I mainly just want to see how much it stick out from the wheel wells.
I threw a bullit wheel of my dad's mustang on the other day and didn't like how it looked at all with the way it stuck out.
bullit...mustang.....
nuff said
its not going to sit inside of the fender if thats what youre asking. itll either be close to flush or just outside. if you run a few degrees of negative camber you can tuck the top of the wheel in, though.
if you look at the rear fender you can see that its still tucking the rear wheels. if they were the +24mm ones they would stick out, therefore, they are the +36mm ones.
you can also fit +30 if you roll your fenders pretty good and use 245/45/18 tires. that has been done.
you can easily tuck the wheels with a few degrees of negative camber, but everyone is like 'omg not weird tire wear!'. negative camber doesnt really effect uneven wear unless youre running excessive amounts ( > 5*).
