Thread: new tires
Results 1 to 18 of 18
  1. #1 new tires
    Kemmerer, Wyoming
    I am interested in upgrading my tire to a wider size and was wondering if 245 was the widest you can run on either a 16", 17" or 18"? im having traction issues and want something that will grip a lot better then the stock 225/60 r16.
  2. #2 Re: new tires
    ill spill some knowledge on you, based on STOCK components.
    the stock 225/60/16 tires are already fairly wide for the stock 7" wide wheels. when you add a 245/50/16 tire on it (doable, many have done it including me) you end up with a lot of tire. this causes the contact patch to be minimized because of the curve the tire needs to take to fit on the skinny wheel. therefore with the stock wheel you should stick with the stock size, but look for a stickier tire.
    if you've got a wider wheel then by all means go with a wider tire. too wide and the tire never gets hot enough to develop the 'sticky' that it should have. too skinny and the tire gets too hot and also has ill effects. normally a 245ish wide tire is going to fit best on an 8" wide wheel.
    so when it comes down to it, what wheel are you running? that will determine your optimum tire size. from there you should find a tire that does what you want in that optimum size.
  3. #3 Re: new tires
    Kemmerer, Wyoming
    so is an 8" wide wheel the optimum width with traction being the goal. are there any stock wheels that are that wide with the same bolt pattern as my 99 gtp. im open to 17's but would prefer to stay with the 16" wheel.
  4. #4 Re: new tires
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    For a 245, 7.5 to 8.5 would be the optimum rim width size. You can put a 245-50 16 on a rim from 7.0 to 9.0 width, as Bio stated the skinnier the rim the more curve the tread has, of course if you go to wide you start to get a concave in the middle which isn't good. A good guide would be split the difference within in the reccommended rim width range that the tire calls out for. Therefore the 8.0 would be the best bet all the way around.
    4 out of 3 people have trouble with fractions
  5. #5 Re: new tires
    Kemmerer, Wyoming
    are there any vehicles that come stock with an 8" wide wheel that will work on our grand prix's?
  6. #6 Re: new tires
  7. #7 Re: new tires
    Kemmerer, Wyoming
    yes they are. I guess my next question is with the larger wheels how concerned should I be with the additional weight? Ive been having a hard time finding the weights of most wheels out there. how much does the stock wheel weigh?
  8. #8 Re: new tires
    weight is always going to be a concern, with anything other than stock. stock wheels are about as light as you are gonna get.
    most of anything is going to weigh more.
  9. #9 Re: new tires
    I live here. TLSheff's Avatar
    Pre-gens had a 16x8 option (not so pretty, but very functional), Bullitt's 17x8s, Saleen's 17/18x8s, GXP's 18x8, research. There are alot of x8 wheels out there for our cars.
    Biggest thing to make sure of is the central bore has to be big enough. most imports won't work because they run a smaller center bore and the wheel won't fit. Ford is one of few that have a bigger hub bore than our cars do. I believe the 350z's will work as well, but I don't think they have a x8 option, unless you get the stanced wheels and I think the offset is too much for our cars on those. Just food for thought.
    Most aftermarket wheels have a 73mm hub bore to accommodate lots of cars.
  11. #11 Re: new tires
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Saleen wheels are dont come in 8" widths. Only 9"
    Both bullits and Saleen wheels are heavy. About 30lbs for a 18x9 Saleen.
    350z wheels wont work unless you open of the wheel bore or run some 10mm spacers.
    The best and lightest mustang wheel is the 17x8 5 spoke GT wheel that come on the 99-04 cars. Just hard to find.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  12. #12 Re: new tires
    Kemmerer, Wyoming
    thanks for the tip
  13. #13 Re: new tires
    Donating User Odi's Avatar
    Chicago South Suburbs
    pregens are 16x7 unless u find the mesh pregens that are 16x8. any stock 97-03 rim (except the three spoke/snowflake) is 16lbs, that includes torque stars and abs fat five spoke wheels.
    you could go find some enkei rpf1's, stupid light for the price and plenty sizes to choose from.
  14. #14 Re: new tires
    T stars are 17ish lbs.
    My 94-96 rims are 17.5 about.
  15. #15 Re: new tires
    ^^ therre was a thread somewhere where iirc ninny weighted out all stock wheels. thats what im going from bruh.
  16. #16 Re: new tires
    Houston/Baton Rouge
    There like 16.xxlb but whatever. Its a pound..
    Unfortunately there's not very many light weight rims for our. Especially in 16"
    I was lucky enough to find some 16x8 weld pro stars couple years ago..
  17. #17 Re: new tires
    GTX Level Member bronzemist02's Avatar
    Canada
    I'm thinking about some rpf1s for my civic. I would go with factory fat five spokes or torque thrusts for the gp with a 225 tire as mentioned before.
    02 GT: Silverstar ultras, nighthawk platinum 2157s, ngk plugs, champion wires, 6k hid fogs, stainless magnaflows, cleaned tips, 2 10" subs. Finally painted.
  18. #18 Re: new tires
    Kemmerer, Wyoming
    [I'm thinking about some rpf1s for my civic. I would go with factory fat five spokes or torque thrusts for the gp with a 225 tire as mentioned before.]
    the goal here is to switch to a wider tire. to my knowledge the factory wheels arent wide enough to support a 245 which is what I want to change to.
  1. Replace 15" tires with 16" tires
    By maxim08 in forum Tires & Wheels
    Last Post: 10-24-2009, 06:44 PM
  2. New Tires
    By bhollamby in forum General Tech Discussion
    Last Post: 10-13-2009, 06:22 PM
  3. New Tires on 98 GT...
    By vicf23 in forum Tires & Wheels
    Last Post: 09-28-2008, 05:14 PM
  4. Anyone ever run, or know anything, about these two tires?
    By Street Wolf in forum Tires & Wheels
    Last Post: 08-04-2008, 07:10 PM
