Thread: need a quick answer will these fit??
Results 1 to 9 of 9
  1. #1 need a quick answer will these fit??
    lebanon, tn
    I am lookin at these wheels and tires I don't have an exact size because they are used but I know they are a 20 inch rim he said the tape measure across the top of the tire was 9.5 inches the tires on my car stock measure just a hair over 8.5 will these rub on my car I have a 2006 grand prix, oh he said they are a 255-35-20 please help I'm new to this stuff thank you
  2. #2 Re: need a quick answer will these fit??
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    theyll bolt rite on if ther your bolt pattern no rub and theyll look good u could put up to a 22 on ur car with no rub
  3. #3 Re: need a quick answer will these fit??
    some actual specs would help. what size is the rim (20 by what)? what is the offset?
  4. #4 Re: need a quick answer will these fit??
    Quote Originally Posted by imdaman3 View Post
    Depending entirely upon the width of the wheel and the tire as well as the spring stiffness.
  5. #5 Re: need a quick answer will these fit??
    Feb 2010
    ohio
    20s will never rub on a 06 gp long as the offest is +35 and width can be up to 8.5-10.0
  6. #6 Re: need a quick answer will these fit??
  7. #7 Re: need a quick answer will these fit??
    Feb 2010
    ohio
    no not risky them cars fit 22s all day long no rub no matter if its a gt gtp i got to of my friends that i sold rims to they bolted um rite on with no problems +35 offset 22x9.5 245 30 22 ,so the 255 35 20 will look nice on it
  8. #8 Re: need a quick answer will these fit??
    SE Level Member 04DetroitLS's Avatar
    Detroit, MI/Lakeshore, ON
    your trans is gonna love you
  9. #9 Re: need a quick answer will these fit??
    yeah, if i run spring blockers i can run whatever size wheel i want without rubbing, but there is a lot more variables than just the offset, rim and tire size.
  1. Oil Leak - I think I know the answer
    By dhall9 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2010, 03:56 PM
  2. Can You Answer This
    By BillDee22 in forum General Tech Discussion
    Last Post: 09-04-2009, 03:37 PM
  3. Quick Question, Easy Answer (bolt size)
    By alexsmith0913 in forum General Tech Discussion
    Last Post: 08-22-2009, 05:25 PM
  4. i need a 4 sure answer!
    By boosting98 in forum Off Topic Discussion
    Last Post: 05-15-2009, 10:29 PM
  5. Question needs an answer!
    By Nickell in forum General Tech Discussion
    Last Post: 12-28-2008, 04:46 AM
