Hello, so i have a 2001 red coupe with ugly ass triangular (aka snowflake)
wheels and am getting sick and tired of them.
So i have around $550 to spend on wheels, i already have Goodyear F1 gs-2's.
Which ones do you think would look better?
First set
Moda Md5
$530 shipped, Tire rack.
Offset: +40mm Backspacing: 6.10" Bolt Pattern: 5-115
Rec. Tire Size: 245/45-18
Weight: 25.0lbs.
(20) Required lugnut for vehicle (Nickel Plated)
(4) MODA MD5 CAP SMALL
(4) Required centering ring
(4) RETAINING CLIP FOR AL-P RING +
Stern St-1
$475 shipped, ebay
Rim Brand: STERNNumber of Bolts: 5Rim Material: AlloyRim Width: 8Bolt Pattern(s) (millimeters): 5x114.3Rim Structure: One PieceRim Diameter (inches): 18Offset: 38Rim Brand: STERNNumber of Bolts: 5Rim Material: AlloyRim Width: 8Bolt Pattern(s) (millimeters): 5x114.3Rim Structure: One PieceRim Diameter (inches): 18Offset: 38
Offset 38
Bolt pattern 5x114.3
18x8
These dont include hub centric rings, im not sure if id need them.
Also how much is it to get a set of wheels and tires mounted and balanced usually?
Thanks
