Thread: 2005 GXP Offset (Help)
Results 1 to 3 of 3
  1. #1 2005 GXP Offset (Help)
    SE Level Member Alwayztru's Avatar
    Indiana
    I realize the offset for FWD vehicles is usually 35+. Can I install wheels with a 15 offset (wheels are from a RWD vehicle) and if so, will they still fit flush in the wheel well?
  2. #2 Re: 2005 GXP Offset (Help)
    no, a +15mm offset is way too low. it will stick out of the fenders and rub horrendously. you need to stay above +30mm for it to work out well in the end.
  3. #3 Re: 2005 GXP Offset (Help)
    Indiana
    Thank you much B/248! Appreciate it greatly!
    "If you're clocked at more than 100 mph...you might as well keep going!"
  1. offset question
    By gpgt04 in forum Tires & Wheels
    Last Post: 09-24-2009, 09:32 AM
  2. Offset
    Last Post: 07-18-2009, 12:30 PM
  3. Offset question, 96 gtp
    By bud6770 in forum Tires & Wheels
    Last Post: 05-11-2009, 12:36 PM
  4. Offset and wheel?
    By speedemongtp in forum Tires & Wheels
    Last Post: 11-30-2008, 10:49 PM
  5. Offset: +40mm
    By xbnb1978x in forum Tires & Wheels
    Last Post: 08-10-2008, 04:22 PM
