Thread: 18s. no clearance and tire rub???
Results 1 to 10 of 10
  1. #1 18s. no clearance and tire rub???
    GT Level Member joshsGT's Avatar
    Nov 2009
    Marysville, MI
    another question guys....18 inch wheels on a GP. is there alot of rub and stuff. i would like to get 18s but my mom who has practically the same car says i wont have any clearance and it would be hard to get into parking spots ect. is this true? i know people out there has 18s, do u guys have these problems?
  2. #2 Re: 18s. no clearance and tire rub???
    youll be fine so long as the offset is anywhere from +45mm to +38mm and you dont run really wide tires (245/255s max).
  3. #3 Re: 18s. no clearance and tire rub???
    Nov 2009
    Marysville, MI
    ok, they are mille miglia evo 5s? i think they look sick as hell but didnt know if theyd fit. the offset is +40. 5x115. 225/40/18 kelly fierce tires. the dude wants 450 for all.
  4. #4 Re: 18s. no clearance and tire rub???
    they will fit perfect. i would put bigger tires on them, but theyll work if you want to run the tires that are on them.
  5. #5 Re: 18s. no clearance and tire rub???
    Nov 2009
    Marysville, MI
    alright man. i saw u have 19s on your green gp right? did you have any rub when you put them on. or did you have to mess witht the suspension when you got them. i just dont want them to be all screwy when i try to make a sharpish turn u know? but thanks duudddee
  6. #6 Re: 18s. no clearance and tire rub???
    Feb 2008
    I've got 255/50/17's on mine. They're 17X7.5 with a 40mm offset, I think. The rears rub a little bit with passengers in the back over bumps or when I'm cornering really hard on a bumpy road. Barely touches, though.
  7. #7 Re: 18s. no clearance and tire rub???
    i had 19" mille miglia ev-s, similar to the evo5. i believe the offset was a little lower than the evo5's and they were an inch bigger. i ran 245/40/19 tires and rubbed on the fenders. once i rolled the fenders all around the car i never rubbed again. it takes an hour or two, a heat gun, and a mallet.
  8. #8 Re: 18s. no clearance and tire rub???
    Nov 2009
    Marysville, MI
    sweet, looks like i got a new set of rims now. cant wait till spring now lol. thanks bro
  9. #9 Re: 18s. no clearance and tire rub???
    Feb 2008
    As soon as I can get my heat guy from home, I'll be rolling my rear ones.
  10. #10 Re: 18s. no clearance and tire rub???
    its not bad once you figure out how hard you can hit the fender before it actually bends the lip.
  1. 2.25" intercooler core and ASCD SD hood? Clearance issues
    By copgtp in forum General Tech Discussion
    Last Post: 11-30-2009, 12:13 AM
  2. tire rack ? about this tire
    By GTPJOE90 in forum Tires & Wheels
    Last Post: 03-09-2009, 09:12 PM
  3. Would these have clearance?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 12-27-2008, 01:29 PM
  4. oil filter s-belt clearance
    By krippled in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 11:55 AM
