My car has 225/60/16's on it now, and I found a set of 235/55/17's pirelli tires for my 17's with less than 5,000 miles for $150. I know there wider, and was just wanting to make sure that they wouldn't rub.
ok just wanted to make sure thanks
Your speedo will be slightly off, im not sure if that matters to you though.
Tire size calculator
just as a heads up, I'm running 245/45/18 tires. I know there are those who have gone wider with tires. A lot of how it will fit is based on your rim... it's width and offset. If you are pretty much running a stock grand prix 17"x6.5" rim then there shouldn't be any problems at all with a 235.
235/55/17 will fit fine. that size is the same size used on all the 17'' rims on the w bodies, such as the comp G 17's impala SS 5 stars, and such and such
