Thread: Replace 15" tires with 16" tires
Results 1 to 8 of 8
  1. #1 Replace 15" tires with 16" tires
    Chicagoland
    Have a 2000 Grand Prix SE with 205/70/15 stock tires. Can I replace them with 245/50/16 rims and tires off another Grand Prix? Trying to find out if they will fit. Want to buy used to save money!!!!
  2. #2 Re: Replace 15" tires with 16" tires
  3. #3 Re: Replace 15" tires with 16" tires
    Donating Users chico's Avatar
    Yes you can mount 16" wheels &tires on your car as long as the bolt pattern is the same,
    04 gto stock,97 GPGT l-36 block diamond pistons ,l-32 rods ,custom comp cam grind,HS 1-7 RR, p&p heads, SS IC,SS M-90 3.5" ,4t60eHD,from Gonzales TX.
  4. #4 Re: Replace 15" tires with 16" tires
    ^keyword is wheels! can't put 16" tires on a 15" rim!
  5. #5 Re: Replace 15" tires with 16" tires
    Quote Originally Posted by maxim08 View Post
    Yes they will fit obviously the others didnt see you said 16 rims and tires off another Grand Prix.
  6. #6 Re: Replace 15" tires with 16" tires
  7. #7 Re: Replace 15" tires with 16" tires
    Chicagoland
    Thanks for everyone's help. I enjoyed the humor. I should have made the title clearer. I want to replace 15" RIMS and tires with 16" RIMS and tires. Just want to make sure the 245/50/16 would fit on a 2000 grand prix SE.
  8. #8 Re: Replace 15" tires with 16" tires
    they'll fit fine! now i understand!
  1. 17" inch GTO wheels with tires
    By GrandPrixGT00 in forum Visual/Body Modifications
    Last Post: 07-22-2009, 10:30 PM
