Thread: Extended wheel studs?
Results 1 to 6 of 6
  1. #1 Extended wheel studs?
    I bought new rims for my car, but the studs do not extend long enough for the lug nuts to actually thread on far enough. The only thing i can think of is extended studs, but i cant find them. Does anyone know where i could find them or have a better solution?
  2. #2 Re: Extended wheel studs?
    Ohio
    I believe the arp wheel studs are longer. Double check but im pretty sure they are
    00 GTP demodded and forsale
  3. #3 Re: Extended wheel studs?
    TDCRacing
    Guest
  4. #4 Re: Extended wheel studs?
    Ohio
    Thanks for clarifying that tdc. i was pretty sure they were but wasnt 100%
  5. #5 Re: Extended wheel studs?
    TDCRacing
    Guest
    No problem. They are a little longer. But i'm not sure hoe much longer he needs them. So i'm not sure if they are going to work or not.
  6. #6 Re: Extended wheel studs?
    I can thread the nut on 2 threads, but im told 6 is the minimum for safety
  1. Wheel studs and aftermarket wheels
    By FuglyGTP in forum Brakes/Suspension/Chassis
    Last Post: 04-14-2009, 03:26 PM
  2. Wheel studs.How hard is it to...
    By GTP4 in forum Brakes/Suspension/Chassis
    Last Post: 04-06-2009, 03:12 PM
  3. Extended Warranties??
    By Blown97 in forum Off Topic Discussion
    Last Post: 01-19-2009, 11:59 PM
  4. wheel studs
    By ibanez0110 in forum General Tech Discussion
    Last Post: 11-10-2008, 07:52 AM
  5. Wheel Studs....
    By Vegas~Blown in forum Brakes/Suspension/Chassis
    Last Post: 08-30-2008, 12:47 PM
