Thread: Stripping silver paint from aluminum wheels
Results 1 to 19 of 19
  1. #1 Stripping silver paint from aluminum wheels
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Has anyone stripped the paint from a set of '95-96 GP 5 spoke wheels and polished them out? I'm talking about a set that is currently painted factory silver.
  2. #2 Re: Stripping silver paint from aluminum wheels
    they make a polished set of those, why not find them and save yourself a lot of work? my brother started to do that with his wheels and decided it was too much work and then just painted them again.
  3. #3 Re: Stripping silver paint from aluminum wheels
    Thunder bay,Ontario.Canada
    A company called Eastwood makes products for that particular task. Here's the link Eastwood Company: Auto Tools, Body Repair, Classic Car Restoration, House of Kolor Paint, Powder Coating
  4. #4 Re: Stripping silver paint from aluminum wheels
    Apr 2009
    They're few and far between from what I know of them. Do you know where I could find a set?
  5. #5 Re: Stripping silver paint from aluminum wheels
  6. #6 Re: Stripping silver paint from aluminum wheels
    Detroit Wheel and Tire. $225.00 a corner for the polished twisted 5 spoke and $200.00 for the polished straight 5 spoke.
    Hope this helps.
  7. #7 Re: Stripping silver paint from aluminum wheels
    SE Level Member snow99dohc's Avatar
    Rugby ND The Center of Nor. Amer.
    I stripped the paint off my silver t-stars for polishing using Aircraft Stripper.
    2003 Pontiac Gran Prix GTP-Thrasher CAI, 180 degree t-stat, AL 104's, ZZP/PT Pcm, ZZP Stg 1 HV TB, ZZP headers, 3'' custom catback, magnaflow mufflers, 3.4''
  8. #8 Re: Stripping silver paint from aluminum wheels
    Apr 2009
    I thought all the torque stars were polished and clear coated from the factory. Is that not right?
  9. #9 Re: Stripping silver paint from aluminum wheels
    there are painted sets too that are just painted silver.
    he is talking about pre-gen rims from a 94-96 grand prix though. they have a slightly lower offset and PONTIAC is printed on one of the spokes. i would run them if i could find a cheaper set because they are nicer than the stock wheels on a 97+.
  10. #10 Re: Stripping silver paint from aluminum wheels
    craigslist is ur friend!
  11. #11 Re: Stripping silver paint from aluminum wheels
    Apr 2009
    I've looked at the help menu there, but I didn't see a way to search the whole USA for a particular item. It seems I have to search city by city.
    Anyhow, I already have the silver wheels - that's the reason I asked about stripping and polishing them. I polish my aluminum wheels on both my truck and my wife's truck, but they were bare aluminum from the factory.
  12. #12 Re: Stripping silver paint from aluminum wheels
    SE Level Member pontiacgp759's Avatar
    Feb 2009
    Ada, OH
    not to butt into this post but if he did strip the paint from his painted rims, would he have to clear coat the bare aluminum?
  13. #13 Re: Stripping silver paint from aluminum wheels
    Apr 2009
    No, they would not have to be clear coated. They could be clear coated, but I would rather have the ability to polish if they need to be done again in a few years, so I would leave them bare. I'm in the same salt belt you're in. We're just east of you outside Marion, Ohio.
  14. #14 Re: Stripping silver paint from aluminum wheels
    Feb 2009
    Ada, OH
    haha yep i hear you man. These winters are rough. I think they put as much salt down as we get snow. I've done some searching for the stock polished 5 spokes and people want an arm and a leg for a set. I have stock white ones that came on my white gp (97) and I'm definitely not fond of them. I'm still working on painting some crosslaces gloss black with a polished lip. I't looks good but i'd still rather have some polished 5 spokes. I think I may work on stripping these white ones. If I end up doing it, I will let you know how they turn out. You're in Marion eh? Do you go to larue ever? I used to go every friday for test and tune.
  15. #15 Re: Stripping silver paint from aluminum wheels
    Apr 2009
    I haven't been there for a LOT of years. I've never ran anything there, though.
    Let me know how your 5 spokes turn out - I'd be really interested. I really believe that once they're stripped, a guy could use some microfinishing compound on the bare metal and shine it up. I know it will take work, but I would think it could be done. The corners would be the toughest parts. The leading outer corners where the brake dust seems to settle is where I mean.
  16. #16 Re: Stripping silver paint from aluminum wheels
    Feb 2009
    Ada, OH
    the only think i'm worried about is if they are anything like my trans am wheels were. underneath the paint the aluminum itself had a pitted texture to it. That would require sanding correct?
  17. #17 Re: Stripping silver paint from aluminum wheels
    but if you clear coated them with an automotive clear after you polished them, then all you would have to do is wax them like the ones on my car.
  18. #18 Re: Stripping silver paint from aluminum wheels
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    Well as long as u don't mind doin the work its worth it. And I mean work. I stripped,primed,painted black, and clearcoated my 18" wheels for like 60 bucks. Bought all of this stuff from oreillys. Its not factory perfect but if u spend a good solid day doin the work its worth it. Mine look great. Look up the videos on how to paint ur wheels on youtube.
  19. #19 Re: Stripping silver paint from aluminum wheels
    Apr 2009
    That's the effect I'm looking for. I'll still wax them, but I prefer no clear, so I can polish them if needed. I wash ours off every day in the winter, anyhow, on our trucks. One more set will only add a few minutes.
  1. Weather Stripping Issue
    By Nickell in forum Visual/Body Modifications
    Last Post: 01-06-2009, 11:05 PM
  2. New pics of wheels and paint
    By 89prix in forum Tires & Wheels
    Last Post: 12-26-2008, 02:12 AM
  3. Aluminum oil pan
    By quiksilvergt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2008, 12:45 PM
  4. Paint my wheels?
    By speedemongtp in forum Tires & Wheels
    Last Post: 10-10-2008, 07:39 PM
  5. Paint honeycomb wheels black?
    By GreenNirvana101 in forum Tires & Wheels
    Last Post: 03-11-2008, 01:50 AM
