Thread: How to clear a malfunctioning TPMS???
Results 1 to 3 of 3
  1. #1 How to clear a malfunctioning TPMS???
    SE Level Member chowndogg's Avatar
    Aug 2020
    Missouri
    Hello! This is my first post so I apologize if I suck at this.
    I bought a 2007 Grand Prix GT that was missing two of the TPMS wheel sensors. I got new tires when it was time to switch and recently got a tire rotation. The car threw a TPMS light at me and a Service Tire Monitor System on the DIC. I checked my tires and the pressure was pretty normal all around the board, but I topped off two that were a little lower. I started the car up to see if anything changed and this time the TPMS light was flashing which I believe indicates a TPMS malfunction. I'm sure that its the two wheels without the sensors that are being dickheads, but I have no idea if I can just reset the TPMS and tell it to **** off (I didn't even get to reset it because everything online that I tried didn't work, and the manual only lists a matching process) or if it will just come back. Thanks in advance boys.
  2. #2 Re: How to clear a malfunctioning TPMS???
    GrandPrix Junkie
    St. Louis
    Why not just replace the 2 missing sensors and go from there? I doubt you can bypass part of the system without a tuner so it will likely keep complaining. Check RockAuto for the sensors if the tire shop wants too much for the parts.
  3. #3 Re: How to clear a malfunctioning TPMS???
    Aug 2020
    Missouri
    Thanks for the quick reply. I have no problems with getting the sensors but I am unsure as to why its only complaining now and if it could possibly be something else? I looked around on the forums a bit and one dude said it went away after a few days of driving so ill just ignore it and see if it leaves me alone. If not then I'll probably grab the sensors and slap em in myself.
  1. Key FOB Malfunctioning?
    By jerryj in forum Audio, Security & Visual Electronics
    Last Post: 03-30-2016, 11:41 AM
  2. clear reflector for clear corners?
    By ndgprix in forum Visual/Body Modifications
    Last Post: 03-26-2011, 10:55 PM
  3. Clear coat leaving white spots on tinted tailights what clear coat would u recomend?
    By MattTheBaker123 in forum Visual/Body Modifications
    Last Post: 05-14-2010, 01:31 AM
  4. DIC Display and A/C Malfunctioning
    By GPGT40 in forum General Tech Discussion
    Last Post: 01-16-2010, 03:24 PM
  5. DIC Display and A/C Malfunctioning
    By GPGT40 in forum Audio, Security & Visual Electronics
    Last Post: 01-16-2010, 01:31 PM
