Thread: Maybe new wheels, need fitment check
Results 1 to 8 of 8
  1. #1 Maybe new wheels, need fitment check
    St. Louis
    I have been looking on and off for wheels and might have found some that I like. I've been through Bio's post on wheel stuff but just want to double check before I spend the coin since I've never bought a set of aftermarket wheels.
    Wheels I'm considering are 18x8, center bore of 73.1 (have hubcentric rings), offset is 45mm, which to my knowledge equals about 6.27 on backspacing. Planning on running 235/45/ZR18 tires.
    What I need to know: Will these clear my Impala front brakes, and do I need to do any fender roll work? I'm lowered on Eibach's also if that matters.
  2. #2 Re: Maybe new wheels, need fitment check
    May 2020
    Pittsburgh
    I would think you'll have serious rub, especially in the rear. I was on 18x8.5 +35 running 245/45/18's on Eibachs and had to roll rears to clear.
    Other way around it would be to run -3*+ camber in the rear.
  3. #3 Re: Maybe new wheels, need fitment check
    St. Louis
    Since these are a 1/2" narrower wheels, would I still need to roll the rears? Is it the offset that messes it up? I'm not really well versed in wheel sizing just yet so just asking to gain knowledge before I get into something that I don't really want to blow extra money on. Plus I need to make sure these clear my front brakes (which I would think they will since my stock 16's clear them).
  4. #4 Re: Maybe new wheels, need fitment check
    May 2020
    Pittsburgh
    The 1/2" is counter by the higher offset, yeah. It's pushed out 10mm, which is slightly less than a half inch, so your setup would fit very similar to mine.
    I would expect to roll rear fenders.
  5. #5 Re: Maybe new wheels, need fitment check
    St. Louis
    Ok, thank you for the info. I kinda figured that might be why.
  6. #6 Re: Maybe new wheels, need fitment check
    Nov 2012
    Madison
    I have 40 ET, 18 x 8 with 245/45/18, not a problem after 5 years and lowered on SSCs
  7. #7 Re: Maybe new wheels, need fitment check
    Dec 2008
    Lawndale, CA
    I’m lowered on the GMPP kit. The first set of 18’s I had were AE077’s. I think they were 18x8, +40. I had to roll the fenders.
    With the fenders rolled I have had no issues with the last two sets of 18’s I had.
    I believe the black 18’s were 18x8, +35 or +40. Can’t remember.
    My current wheels are 18x8 +35 and no issues with rolled fenders.
  8. #8 Re: Maybe new wheels, need fitment check
    Nov 2012
    Madison
    I guess it was 7 years ago.
    Mike, maybe the rolling was necessary because our cars are a different series.
    I have a roller I may never use again. $45 from ebay and worked like a charm on my 08,535xi
  1. SD Lip fitment ?
    By robbiegtp in forum Visual/Body Modifications
    Last Post: 06-04-2016, 12:09 AM
  2. Rim Fitment?
    By Boostdgtp in forum Tires & Wheels
    Last Post: 01-12-2012, 09:47 AM
  3. fitment
    By jayrodmiller in forum Tires & Wheels
    Last Post: 03-15-2011, 02:28 PM
  4. Check It Out (BMW w/ Bugatti Wheels)
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 03-13-2011, 07:48 PM
  5. Need help with wheels fitment.
    By og512 in forum Tires & Wheels
    Last Post: 06-19-2009, 12:27 PM
