Thread: C5 ZO6 Wheels on a 97-03
Results 1 to 20 of 24
  1. #1 C5 ZO6 Wheels on a 97-03
    SE Level Member GrandPrixGT1's Avatar
    Jan 2017
    Mount Airy, MD
    Does anyone run the front 17" C5Z wheels on their GP (97-03)? Was offered 4 of them and I love the way they look and wanted to put them on. the specs are as follows
    Wheel size: 17x9.5
    Offset: +54mm
    Tire Size: 265/40/17 would probably do a 275/40
    Back spacing 7.38"
    I found some 5x115 to 5x120 conversion hubs that are 1" thick on eBay. The tire is shorter then our size just wider.
  2. #2 Re: C5 ZO6 Wheels on a 97-03
    likely rub all over with the spacer deal.
  3. #3 Re: C5 ZO6 Wheels on a 97-03
    Jan 2017
    Mount Airy, MD
    Our offset Is 52mm. I feel like it would work. Trying to find someone with a similar wheel being that its only a 17" the width is what would be a problem.
  4. #4 Re: C5 ZO6 Wheels on a 97-03
    the width and the extra inch will likely put them in the fenders. test fit might be in order if possible.
  5. #5 Re: C5 ZO6 Wheels on a 97-03
    Yeah, 3in wider wheels is going to rub. Then add the spacer to make it worse.
  6. #6 Re: C5 ZO6 Wheels on a 97-03
    Jan 2017
    Mount Airy, MD
    What's it going to rub on? How are people running 20x10s? Other then the rubbing will it fit and be driveable?
  7. #7 Re: C5 ZO6 Wheels on a 97-03
    I've never seen anyone fit 20x10's on a grand prix.
    Tires are going to hit the strut perch and or the fenders.
  8. #8 Re: C5 ZO6 Wheels on a 97-03
    Jan 2017
    Mount Airy, MD
    You would need spacers to space it out enough so it doesn't hit the perch
  9. #9 Re: C5 ZO6 Wheels on a 97-03
    Well then do it and lets see how it looks with some goofy spacers on there.
  10. #10 Re: C5 ZO6 Wheels on a 97-03
    Jan 2017
    Mount Airy, MD
    The adapters I'd need are 1" thick. Someone somewhere has got to have put 5x120 wheels on a GP
  11. #11 Re: C5 ZO6 Wheels on a 97-03
    Oct 2011
    Toledo, OH
    I have 1" spacers on stock 17". They stick out past the fender by half inch. I'm lowered 1.7" also but I'm pretty sure you are not going to fit another +1" under there.
    C5 ZO6 Wheels on a 97-03 Attached Images
    7"
  12. #12 Re: C5 ZO6 Wheels on a 97-03
    Oct 2011
    Toledo, OH
    Me = left, stock = right. Look at the difference in the front stick out.
    7"
  13. #13 Re: C5 ZO6 Wheels on a 97-03
    SWPA
    The stock 17's pictured are only 6.5" wide. As he stated he has 1" spacers on them. Add another 3" for the 9.5" wide wheels and you are going to look absolutely ridiculous.
    Also the specs on those being 54mm offset, will change to ~29mm offset with the 1" spacer.
    As previously stated no one runs a 10" wide wheel on a W body. Most people stick with 8" wide. Hell I thought of throwing my 9" wide, 30mm offset wheels on it and they wouldn't have worked without rubbing.
    Your 10" wide 28mm offset (after spacer) wheels aren't going to work.
  14. #14 Re: C5 ZO6 Wheels on a 97-03
    Oct 2011
    Toledo, OH
    Just to clarify, his 9.5"+ 1"spacer would only be 2.5"ish closer to fender.
    So you'd be going an additional 1.5 past what you see on my car.
    7"
  15. #15 Re: C5 ZO6 Wheels on a 97-03
    Sep 2015
    Cheyenne, WY
    225/55-17 vs 265/40-17 Difference
    Diameter inches (mm) 26.74 (679.3) 25.35 (643.8) -1.4 (-35.5) -5.2%
    Width inches (mm) 8.86 (225) 10.43 (265)
    1.57 (40) 17.8%
    Circum. inches (mm) 84.02 (2134.08) 79.63 (2022.56) -4.39 (-111.53) -5.2%
    Sidewall Height inches (mm) 4.87 (123.75) 4.17 (106) -0.7 (-17.75) -14.3%
    Revolutions per mile (km) 754.11 (468.58) 795.7 (494.42) 41.58 (25.84) 5.5%
    2007 Antique Bronze Metalic Grand Prix GT...bone stock.
  16. #16 Re: C5 ZO6 Wheels on a 97-03
    Oct 2011
    Toledo, OH
    Yep. 1.57 inches + the 1" space = 2.57 closer to fender.
    7"
  17. #17 Re: C5 ZO6 Wheels on a 97-03
    Sep 2015
    Cheyenne, WY
    Some very smart people have offered their advice on why this
    car/wheel/tire combination would either not work or look goofy as all hell.
    They all agree on one point...Don't do it.
    I've never been one to play follow the leader so with that in mind, I say go for it!
    Post a picture showing us how the tires don't rub & don't stick out so far from the fenders that it looks like it should be driven by a circus clown with big floppy feet!
    Let us know how it works out for ya.
  18. #18 Re: C5 ZO6 Wheels on a 97-03
    Sep 2015
    Cheyenne, WY
    And be sure to put some rock hard springs on all 4 corners.
    Well unless you don't plan on turning the wheels left or right.
  19. #19 Re: C5 ZO6 Wheels on a 97-03
    hangover park IL
    Your best option is to install the C5 Corvette wheel bearing and hub assembly on the Grand Prix
    ~James~ Psychotic Gearhead
  20. #20 Re: C5 ZO6 Wheels on a 97-03
    Oct 2011
    Toledo, OH
    Quote Originally Posted by LEVELX View Post
    Because tires don't move straight up and down, there is still a chance it COULD work. Obviously without camber and the rotation of the control arms etc, my wheels wouldn't clear. Stock good condition struts and springs MAY clear the fender but it's one of those things that math and probability is working against you.
    7"
  1. WTB or WTT 18" alcoa wheels for CompG wheels
    By Spawne32 in forum Wanted To Buy - Parts
    Last Post: 09-18-2016, 08:05 PM
  2. 2002 Grand Prix GTP - Uograde Wheels to a 17" 40th anniversary Edition Wheels
    By phogstenjr in forum Introductions/Noob Questions
    Last Post: 01-10-2015, 03:02 PM
  3. Thinking of getting these wheels ** Wheels are in **
    By Silver2kgtp in forum Tires & Wheels
    Last Post: 03-11-2013, 04:52 PM
  4. aftermarket wheels on GXP (staggered stock wheels)
    By canuckgxp in forum Tires & Wheels
    Last Post: 03-15-2012, 11:36 PM
