Thread: Stock wheel issues....?
Results 1 to 5 of 5
  1. #1 Stock wheel issues....?
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    Stock wheels won't sit flush, obviously can't get lug nuts on because of it....anyone ever run into this issue?
  2. #2 Re: Stock wheel issues....?
    St. Louis
    What did you change that caused the wheels to not sit flush?
  3. #3 Re: Stock wheel issues....?
    GTP Level Member buickman104's Avatar
    NYC
    Need moar details!
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  4. #4 Re: Stock wheel issues....?
    HUDSON
    If the brakes have been upgraded, check that the caliper is not hitting the rim.
  5. #5 Re: Stock wheel issues....?
    Nov 2012
    Madison
    Quote Originally Posted by rodguezsciii View Post
    Are you talking about the 17" split 5 spokes?
    How are the backs? Is this every wheel. Like maybe your hub centric rings were still on the hub??
  1. Scanning ABS wheel sensor issues.
    By mainecrab in forum General Tech Discussion
    Last Post: 11-25-2015, 06:40 AM
  2. wheel speed sensor issues
    By jhintz in forum General Grand Prix Discussion
    Last Post: 05-19-2014, 05:26 PM
  3. Transmission and steer wheel issues????
    By Aklilu Kassa in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-16-2011, 08:37 AM
  4. Back to stock... Have a few issues.
    By Bedwards in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-06-2011, 08:30 PM
  5. Issues with the stock air fliter box
    By Dagujugrandprix08 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2009, 11:53 PM
