Thread: I'm still looking for an 18" super light wheel
Results 1 to 10 of 10
  1. #1 I'm still looking for an 18" super light wheel
    Slower, Lower Delaware
    I've found a Lexus es350 wheel that is 5 x 114.3 and has a 35mm offset and is 18x8. it's under 19lbs.
    Shouldn't I be able to run those?
    TIA
  2. #2 Re: I'm still looking for an 18" super light wheel
    Nov 2012
    Madison
    Yeah,all day with 245/45s
  3. #3 Re: I'm still looking for an 18" super light wheel
    SWPA
    You need to verify the center bore is large enough.
  4. #4 Re: I'm still looking for an 18" super light wheel
    Kemmerer, Wyoming
    I think it needs to be 70.3 mm hub bore
  5. #5 Re: I'm still looking for an 18" super light wheel
    Jul 2010
    Coquitlam,BC,Canada
    The Lexus ES350 wheel has a 60.1 center bore, GP needs 70.3.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: I'm still looking for an 18" super light wheel
    Nov 2012
    Madison
    I forgot that 1 small thing, duh
  7. #7 Re: I'm still looking for an 18" super light wheel
    Thank you guys.
    I'm not sure what offset to run. My current wheels are 18x8 and have a 42 offset. I like the way they look.
    I can find a couple of ford wheels i like but the offsets are all over the place.
  8. #8 Re: I'm still looking for an 18" super light wheel
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Mine have the same specs, weight is 21.75 lbs each. Wish they were lighter, stock torque stars are only 16 lbs.
    Sport Edition P2
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  9. #9 Re: I'm still looking for an 18" super light wheel
    Quote Originally Posted by Burbman View Post
    Sport Edition P2
    Not a bad wheel. I'm looking for an 18x8 that is 19# or under and bright.
  10. #10 Re: I'm still looking for an 18" super light wheel
    I've found a couple of light 18X8 wheels for Mustangs. I'm running 235x50x18. What offset would look best?
  1. 2000 Grand Prix "TEMP" light on dash when cold outside.
    By DerrickCaldwell in forum Introductions/Noob Questions
    Last Post: 01-07-2017, 09:58 AM
  2. 97 Grand Prix GT "check tire pressure" light on
    By fju2 in forum General Tech Discussion
    Last Post: 08-04-2011, 07:37 PM
  3. "rear" wheel hub replacement question
    By 03GPGTOWNER in forum Brakes/Suspension/Chassis
    Last Post: 11-10-2010, 10:39 PM
