Thread: New Wheels for the GTP
Results 1 to 7 of 7
  1. #1 New Wheels for the GTP
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Well, after my third bent torque star causing a vibration at speed, I decided to pull the trigger on these:
    18x8, 42mm offset. Going with Michelin Pilot Sport 245/45-18 tires. Ordering the whole thing mounted and balanced from TIRE rACK.
  2. #2 Re: New Wheels for the GTP
    Jul 2010
    Coquitlam,BC,Canada
    Good lookin' wheel.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: New Wheels for the GTP
    Dec 2008
    ****'s Creek
    Hoping I don't have any rub issues with the W-Body trailing arms and Vogtland springs, but looks like the 42mm offset will put the wheel where it needs to be. Never had 3 bent wheels inside of 6 months, hoping I'm not asking for more trouble with 245 tires...
  4. #4 Re: New Wheels for the GTP
    Dec 2008
    ****'s Creek
    I finally had some time to put these on the car Saturday. The 42mm offset was perfect, if you factor in the amount that the tire sticks out from the rim, the inside face of the new 245/45-18 tire is exactly where the old 225/60-16 was, so suspension clearance stays exactly the same. On the outside, the new tire is about 3/4" wider than the OEM size, so it sits closer to the fenderwell. I am running Vogtland springs so the car is lowered, but tires aren't even close to rubbing. If I loaded the car with luggage and passengers it might be close, but not convinced they would rub.
    Also went with Gorilla black chrome lugs, the "every one is a lock" is overkill, but I like the nice clean acorn look of the lugs. These wheels are also hub-centric with a 70.3mm center bore.
    Worth noting, I was concerned about ride quality going to a lower profile tire with the stiffer Vogtland springs and GMPP sway bars. Each tire/wheel combination is about 10 lbs heavier than a stock torque star and Goodyear tire, so unsprung weight is up 40 lbs overall. I was surprised that the car rides better with this new set up. Where I had a lot of bounce before, these tires stay planted on the road, and it smoothed the ride out quite a bit.
    As expected, steering response is off the charts, so much so that the wheel is almost a little twitchy.
  5. #5 Re: New Wheels for the GTP
    Jul 2010
    Coquitlam,BC,Canada
    Looks good.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: New Wheels for the GTP
    Dec 2008
    Lawndale, CA
    They look much better than the factory wheel.
  7. #7 Re: New Wheels for the GTP
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Looks really good
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  1. 2002 Grand Prix GTP - Uograde Wheels to a 17" 40th anniversary Edition Wheels
    By phogstenjr in forum Introductions/Noob Questions
    Last Post: 01-10-2015, 03:02 PM
  2. GSX wheels
    By jsnyder49090 in forum Tires & Wheels
    Last Post: 02-25-2014, 01:29 PM
  3. Thinking of getting these wheels ** Wheels are in **
    By Silver2kgtp in forum Tires & Wheels
    Last Post: 03-11-2013, 04:52 PM
  4. aftermarket wheels on GXP (staggered stock wheels)
    By canuckgxp in forum Tires & Wheels
    Last Post: 03-15-2012, 11:36 PM
