Thread: Any reason I shouldn't run this Mustang wheel?
Results 1 to 12 of 12
  1. #1 Any reason I shouldn't run this Mustang wheel?
    Slower, Lower Delaware
    Front and Rear
  2. #2 Re: Any reason I shouldn't run this Mustang wheel?
    Kemmerer, Wyoming
    I'd rock those, I like the shiny look.
  3. #3 Re: Any reason I shouldn't run this Mustang wheel?
    I don't want black so it's about the only wheel I can find under 19 lbs.
  4. #4 Re: Any reason I shouldn't run this Mustang wheel?
    Kemmerer, Wyoming
    For such a big wheel, they do seem pretty light weight
  5. #5 Re: Any reason I shouldn't run this Mustang wheel?
    St. Louis
    Looks like they'll work. Found this on a quick search--> http://www.grandprixforums.net/threa...alken-FK-452-s
  6. #6 Re: Any reason I shouldn't run this Mustang wheel?
    Nov 2012
    Madison
    Nice wheel.
    a wee bit lower offset would look better on the car
  7. #7 Re: Any reason I shouldn't run this Mustang wheel?
    Quote Originally Posted by spazzz View Post
    Nice wheel.
    I thought that too but This is the only way I saw them.
    I'll run 50 series on them as that's what I have already.
  8. #8 Re: Any reason I shouldn't run this Mustang wheel?
    Nov 2012
    Madison
    http://www.1010tires.com/Wheels/enkei/PF01
    They have a 18 x 8.5 with a 35 offset.
    Also a 18 x 8 in 40.
    over 300 a wheel
  9. #9 Re: Any reason I shouldn't run this Mustang wheel?
    SWPA
    Quote Originally Posted by Sudden View Post
    the second number, ie 50 as you say, determines the height, not the width.
  10. #10 Re: Any reason I shouldn't run this Mustang wheel?
    I just mentioned that because the recommended tire series is a 45, and that is what the guy in the article Fordman77 connected me to was running.
    To get the right height for that aspect ratio I'll be running a 235 and not a 245. What aspect ratio you want to run really changes the size of tire you want to buy. The overall diameter of about 27" has to stay the same, so every time you change the
    aspect ratio the tire size changes. it's always going to be a 27" tire the bigger the aspect ratio the bigger the sidewall will be.
  11. #11 Re: Any reason I shouldn't run this Mustang wheel?
    Well tirerack has this wheel in 35 offset in silver. According to the tire spec for my Conti extreme contact DWs in 235-50/18 the rim size is 6.5 to 8.5. So they should be OK. It will be the first time i've tried a Mustang wheel.
  12. #12 Re: Any reason I shouldn't run this Mustang wheel?
    235 on an 8.5" wheel is plenty wide.
    i've got 245s on my 9.5" wheels and they're fine, too.
  1. Knocking when it shouldn't
    By Dadkota in forum PCM Tuning
    Last Post: 01-01-2016, 09:26 AM
  2. shouldn't have said anything
    By NR92 in forum Track Sessions and Kills
    Last Post: 07-29-2012, 09:06 PM
  3. Mustang wheel question
    By pacer07 in forum Tires & Wheels
    Last Post: 05-20-2011, 11:24 PM
  4. mustang wheel offset
    By quinnp12 in forum Tires & Wheels
    Last Post: 12-02-2009, 08:38 PM
  5. Mustang Bullet Wheel questions...
    By Iron Indian in forum Tires & Wheels
    Last Post: 02-23-2009, 08:59 AM
