Thread: Will my wheels rub
Results 1 to 20 of 20
  1. #1 Will my wheels rub
    Jan 2016
    Oregon
    Will 19x8.5 wheels on 245/40/19 tires and 30mm offset (1.2 in) on ssc lowering springs rub on an 04-08 grand prix
  2. #2 Re: Will my wheels rub
    The overall diameter is fine for the speedo but with that offset and a wide rim I think it will rub in the rear for sure.
    Roll your fenders and it might be alright. You'll have to test fit things to be sure.
  3. #3 Re: Will my wheels rub
    Nov 2011
    NY
    Yes
  4. #4 Re: Will my wheels rub
    Jan 2016
    Oregon
    What exactly do they rub against when theyre wide, the struts? What safe wheels sizes do you guys recomend
  5. #5 Re: Will my wheels rub
    They rub the fenders like I said. It may rub the struts but I don't know for sure with that size rim and tire combo.
    My only dislike about 19's is the stupid prices they charge on tires. Running a 18x8 with a +40 offset is always a great fit on these cars.
  6. #6 Re: Will my wheels rub
    Jan 2016
    Oregon
    The problem with that is the wheels I want only come 19x8.5 30mm offset and 18x8 30mm offset. They 19s with 245/40/19 will really rub against the fenders? My buddy has 20x8.5 with ssc and he doesnt rub? Didnt roll his fenders either
  7. #7 Re: Will my wheels rub
    Why are you so against just rolling the fenders if they rub... Every car is different.. Worn suspension plays a part. Just roll them if they do rub just because X or Y didn't rub doesn't mean you won't but if you do you know what to do to fix your issue.
    04 Comp G.
  8. #8 Re: Will my wheels rub
    hangover park IL
    Quote Originally Posted by GrandPrix541 View Post
    helluva difference between a 30mm offset and 42-48mm offset i see on most 20's
    like about half an inch or more
    ~James~ Psychotic Gearhead
  9. #9 Re: Will my wheels rub
    those should be fine, but as mentioned you might need a fender roll. the rear is going to be more likely to rub.
    i ran a set of wheels with about the same exact specs on eibach springs. once the fenders were rolled i was golden.
  10. #10 Re: Will my wheels rub
    Jan 2016
    Oregon
    Would 18x8 be a better choice
  11. #11 Re: Will my wheels rub
    well, yes as far as clearance goes, but the 19x8.5s are going to look much better (obviously style dependent).
    what do you have against rolling the fenders? you can easily gain enough clearance with a heat gun and a rubber mallet to get away with this and it'll only take you about an hour of your time...
  12. #12 Re: Will my wheels rub
    Jan 2016
    Oregon
    No I have nothing against rolling renders, but obviously if theres a size that I like that requires nothing to be done I would prefer it. But I am most likely going with the 19x8.5 and roll the fenders. Is there any professional places that do it, I dont wana mess it up lol
  13. #13 Re: Will my wheels rub
    most body shops can do it and some performance shops that do lots of wheel/tire setups can do it, too.
    it's super easy to do by yourself, though...
  14. #14 Re: Will my wheels rub
    Jan 2016
    Oregon
    Could I use a hairdryer instead of a heat gun, and just hit it with a rubber mallet righr
  15. #15 Re: Will my wheels rub
    GT Level Member Jnibbs24's Avatar
    Sep 2015
    Seattle
    Hairdryer doesn't produce near the heat from a heat gun, use the right tools or head over to the Honda forum after you trade in your Grand prix.
  16. #16 Re: Will my wheels rub
    you can pick up a heat gun for under $20, my guy. go to the store.
    but we're also just guessing at this point. you won't know if you rub until you put them on or if you spend a couple hours taking really exact measurements.
  17. #17 Re: Will my wheels rub
    Jan 2016
    Oregon
    Nah Id rather not be a ricer. Ive just heard that you can use hair dryers for a couple aplications that require heat guns. Ill just buy a heat gun then, thanks
  18. #18 Re: Will my wheels rub
    Dec 2015
    Kansas
    Will 17" zo6 wheels fit my 04 gtp comp g
  19. #19 Re: Will my wheels rub
    no. wrong lug pattern.
  20. #20 Re: Will my wheels rub
    Quote Originally Posted by Clarkshark35 View Post
    Wrong bolt pattern there 5x120
    Yours is 5x115 but 5x114.3(4.5) would work
    04 Comp G.
  1. 2002 Grand Prix GTP - Uograde Wheels to a 17" 40th anniversary Edition Wheels
    By phogstenjr in forum Introductions/Noob Questions
    Last Post: 01-10-2015, 03:02 PM
  2. Thinking of getting these wheels ** Wheels are in **
    By Silver2kgtp in forum Tires & Wheels
    Last Post: 03-11-2013, 04:52 PM
  3. aftermarket wheels on GXP (staggered stock wheels)
    By canuckgxp in forum Tires & Wheels
    Last Post: 03-15-2012, 11:36 PM
  4. New wheels!
    By Fem in forum Tires & Wheels
    Last Post: 03-01-2012, 02:21 AM
