Thread: Gas Pumps
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Gas Pumps
    SE Level Member a_v_s's Avatar
    PacNW
    HAAAAA! I got you BEAT sucka! I put 18.1 I believe it was and I have a receipt.
    Be aware that many gas stations have vapor recovery systems (required in some jurisdictions). If you pump too much gas in, the extra gas could get sucked up by the vapor line, and it will be put back in the gas station's holding tank, even tho you already paid for the gas.... That's one of the reasons you should never top off.
  2. #22 Re: Gas Pumps
    Oklahoma
    I dont think they do around here. However, sometimes the handles are so sensitive and shut off automatically so easily that I'll hold the nozzle out of the fill port (that little disc that the nozzle pushes open) and just lightly press the handle so the gas just barely flows out. I'll continue to fill up that way until just about the point no more gas will go in.
    The only draw back to this I have ever found is that I guess the EVAP system or something doesnt like it to be WAY filled up because if you do, at least in my car, it will buck and shudder and even stall sometimes until it consumes some of that gas. So over time Ive gotten pretty good about staying under that point.
  3. #23 Re: Gas Pumps
    Port Hope Ont,Canada
    I try not to go under half but at the same time can
    not fill it up either have a leak...
    1998 GTP, U-Bend Delete,Hi-Flow Cat,No Res,SLP Headers,BRISK Plugs ,180 T-Stat, 3.4 pully
    2007 GM Show and shine August 10http://www.youtube.com/v/aRh91q1jRio&rel=1
    OQCGP Clubhttp://www.youtube.com/v/j_YHmgU9ehs&rel=1
  4. #24 Re: Gas Pumps
    GTP Level Member David99GTP's Avatar
    Florida
    Ever have the opposite? I had a pump that seems to take an hour to push out a gallon.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  5. #25 Re: Gas Pumps
    Oklahoma
    Quote Originally Posted by David99GTP View Post
    I have on a few occasions. I usually just let go of the handle and let it sit for a few seconds and then start again. Usually it starts running like it should. I dont know what it is but that usually works.
  6. #26 Re: Gas Pumps
    Florida
    I'm gonna have to try that, Thanks
    1999 GTP
