Thread: sae vs metric
Results 1 to 16 of 16
  1. #1 sae vs metric
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    While working on my 97SE and others in the junkyard, it has become quite irritating how some bolts are SAE and others are metric. This makes the conversion tables in the manuals indispensable. Are the 04+ GP's any better or just as big a crap shoot?
  2. #2 Re: sae vs metric
    Charles City, IA
    Pretty much everything on a 3800 is metric besides the valve cover bolts.
    SMGPFC Two Nipple General
  3. #3 Re: sae vs metric
    new cars for the last 15 years or so have all been built with metric bolts, for the most part, that's all makes and models, metric is so much easier to use anyways.
  4. #4 Re: sae vs metric
    Grand Island, Nebraska
    Correct me if im wrong but I think the front bolts of the downpipe are metric and the rear ones are SAE... wtf
  5. #5 Re: sae vs metric
    Lakeside Park, KY
    Quote Originally Posted by TheOtherNick View Post
    That's not been my experience. Yeah, you could use a 13mm on some bolts, but there is a little play and a 1/2" fits perfectly. Like the dog bones or the fender braces. I don't remember off the top of my head, but I know there were some SAE bolts when I taking the heads off in the junkyard for a top swap. I think they were 7/16.
  6. #6 Re: sae vs metric
    Charles City, IA
    dog bone=15mm
    fender brace=13mm
    supercharger=10mm, one 13mm
    tb=10mm, 2 8mm on the support bracket for n/a cars
    egr=13mm
    valve cover=3/8
    alt bolts and nut= 15mm
    map bolts=10mm
    water pump pulley=8mm
    front cover and water pump 10mm and 13mm
    crank bolt=15/16
    rear cover=3/8
    oil pan 3/8
    head bolt= 5/8IIRC
    head stud nut= 1/2" 12 or 6 point
    x over nuts= 13mm
    starter bolt=15mm
    starter batter pos nut=13mm 14mm on some after market
    starter relay wire=10mm
    p/s pump=13mm
    tensioner pulley=15mm or t55 torx
    icm bracket=15mm
    cam bolt= 1 1/16" or 24mm IIRC
    torque converter bolts=18mm
    transmission bell-housing bolts=18mm
    rear engine to trans bracket bolts=13mm
    axle nut 32-36mm depending on year and axle manufacturer
    strut to knuckle bolts=21mm
    ball joint nut=18mm 19mm on some aftermarket
    strut top nuts 15mm
    front sway bar bushing clamp bolts=15mm links 13mm-15mm depending on manufacturer
    rear sway bar link nuts=18mm, 15mm on back to hold the ball
    manifold bolts 13mm
    02 sensor= 7/8"
    icm harness bolt=7mm
    Lim bolts=3/8"
    hub bolts=1/2"
    blower motor/blower resistor 7/32"
    small dash bolts=7mm larger ones 13-18mm
    Seat bolts=T60 torx IIRC
  7. #7 Re: sae vs metric
    Mercer, Pa
    I figure the engine internals are English because the engine was designed back when everything was English. They wouldn't change to metric unless completely redesigning such as a new engine.
  8. #8 Re: sae vs metric
    but they kinda did with the series II.
  9. #9 Re: sae vs metric
    HUDSON
    It all depends on the cheapest bolt supplier.
  10. #10 Re: sae vs metric
    Mercer, Pa
    The blocks are milled on cnc mills already set up for drilling and tapping English. To drill some holes English and some holes metric would require adding more tooling. I would guess every tapped hole in the block, crank and heads are English. The rest of the car and engine brackets are probable metric.
  11. #11 Re: sae vs metric
    didn't see these in a quick skim.
    LIM bolts 3/8"
    Wheel hub bolts 1/2"
  12. #12 Re: sae vs metric
    Lakeside Park, KY
    Thanks for the list Nick. That should come in handy for a lot of jobs. If I hadn't started this as a rant, that would be an awesome sticky. It does prove my point that GM was inconsistent though. Are those sizes accurate for the 04+ vehicles?
  13. #13 Re: sae vs metric
    I hate to say it and I'll put the flame suite on for it. EVERYTHING should be metric!! I fvckin hate SAE! Lets see if a 10mm is too small grab a 11mm done! None of this fraction crap. At the very least build the whole damn vehicle with one or the other! Not half and half. Bi-polar assembled cars are like dealing with my wife!! LMFAO and trust me thats enough!!
  14. #14 Re: sae vs metric
    On 99% of stuff you are fine grabbing the next up or down. But at the 10mm/3/8 size with the rounded edge bolts that GM used, yeah. It's kinda necessary.
  15. #15 Re: sae vs metric
    Lakeside Park, KY
    The 13mm and 1/2" sizes are real close too. I checked a lot of the 13mm's Nick posted above. They all have a little play and are dead on for the 1/2". The funny thing is, they have the metric strength markings.
  16. #16 Re: sae vs metric
    MO
    My dad (engineer) hates the metric system, and for a legitimate reason: if you're a decimal place off by multiplying by a wrong power of 10, it's much harder to spot than just a plain wrong number you can find in standard English. I'm indifferent.
    <brandonl2000> LMAO D!!
  1. 98 GTP dual climate control-metric?
    By Liquifire in forum General Tech Discussion
    Last Post: 07-26-2009, 03:41 PM
  2. HUD turned metric!
    By foghelmut in forum General Tech Discussion
    Last Post: 07-19-2009, 11:27 PM
  3. Best place to get metric bolts?
    By 99prixgt in forum General Tech Discussion
    Last Post: 03-29-2009, 08:20 PM
