When an unstoppable force meets an immovable object something got to give right...
2 hours ago · Like ·
Eden Roseborough, Amethyst ImaStar Hudson and Michelle Barnes like this.
Kevin Steelwheelz Jackson Nothing gives they both crumble in place and nobody wins in my opinion
about an hour ago · Like
Um Juss Sayin yea.........a collision for change.......
Shatila Barnes @Kevin, im inclined to agree, but even if they crumble somethin still gave right because they are no longer unstoppable and immovable @BIG, yeah def a collision but is the force and object both destroyed or jus altered so that they can take on a new form, this is what im tryin to figure out....
about an hour ago · Unlike · 1 person
Um Juss Sayin both are in a recompense for change......
about an hour ago · Like · 1 person
Kevin Steelwheelz Jackson Good question i think once they crumple it is only then and them that can decide to rebuild 2 unstoppable unmovable objects or build 1 better......
Shatila Barnes @BIG def r but do u rebuild as a strong joint unit dependent on one another remain unstoppable and immovable or as a 2 seperate units that dont rely on any outside components @kevin, i agree once again, but if you dont kno the answer to that then how do u avoid the path of direct collision or destruction bcus of dependence?
Kevin Steelwheelz Jackson Faith or No Faith, you dodge it by leaving it alone and not having to deal and you go head long by faith and pray that the outcome is a stronger unity being rebuilt
Shatila Barnes I think u r rite 100%
Kevin Steelwheelz Jackson ;-)
Um Juss Sayin its impossible to build as a joint......cause one must move and one is stoppd......if u combine u have an unstoppable immovable force....~ OXYMORON ? ~...hows dat possible.......u have to rebuild each as it was or similarly is the only way.......
Kevin Steelwheelz Jackson OXymoron is why you walk by faith because nothing that makes sense happens by the will of man
about an hour ago · Like · 2 people
Shatila Barnes @BIG, not necessarily bcus if they take the rite parts of each unit to construct a new unit... that can be a powerful structure but there is anotha solution that most ppl dont see...if the unstoppable force goes around the immovable object to begin with then the collision is avoided and both the force and object remain in tact...
Michelle Barnes THATS MY LIL CUZ FOR YOU
Shatila Barnes Lolz u kno im like a clock... my mind is always ticking! Tryin to find a way thru this thing we call life
Um Juss Sayin if u move it then its not immovable........and if u stop it then its not unstoppable....COME ON FOR REAL.......and if the unstoppable goes around .....then only the unstoppable is ...giving ....because it changed its course to go around the immovable .....so in preclusion u were exemplifying a question as in pertaining to does sumthn have to give when the two meet..........its jus the picture paintd with the dramatics of words would have one to insinuate there is gonna b a collision .......hhmmmmm.......
58 minutes ago · Like
Um Juss Sayin FAITH WITHOUT WORKS IS DEAD........
57 minutes ago · Like · 1 person
Shatila Barnes @BIG i ddnt use my words to incenuate anything, but i did use them to cause a persons subconscios to respond in a way that shows whether they prevent problems or react to them...but wut u are failing to realize is that a force is not somethin that can only be in motion it is somethin that can also be stationar...i can be an unstoppable immovable force by being a unit that does not move until i decide to move...and u rite faith without works is def dead but sumtimes the work the work is stayin still until its time to move especially when your environment is promptin u to move prematurely...
50 minutes ago · Like
Um Juss Sayin an oxy moron is to opposite words joined to get a truth or positive effect........an immovable unstoppable force is impossible
49 minutes ago · Like
Shatila Barnes *subconscience
Um Juss Sayin ....?....
48 minutes ago · Like
Shatila Barnes Im quite aware of what an oxymoron is and immovable and unstoppable are two words that are opposite but not immpossibe
47 minutes ago · Like
Kevin Steelwheelz Jackson Yes that is why i said that you have to go for the colliision expecting to try to build into something better after words and through faith and your belief, if it is in God's will then it will happen
42 minutes ago · Like
Um Juss Sayin so when u combine immovable and unstoppable wut do u get ?.........an impossibility no matter wut.......
40 minutes ago · Like
Kevin Steelwheelz Jackson Exactly and no matter what man says anything that is impossible has eventually been done through faith. Walking on the moon was impossible faith and determination. GRasping electricity and using it for the many things we do today was unheard of edision was seen as a fool with a kite, The many people in martial arts and various other forms of self control have used the mind over matter technique to do thinks unfathomable, The internet and facebook we are on right now 10+ years ago would have been laughed at but someones dream faith and determination brought all this to us. So it may seem an impossibility but nothing is impossible. An immovable unstoppable hybrid would be able to stay on a single path that is chose with out anything to get in its way because it will not be moved from the path it choses and it will not be stopped by any obstacles put in its way
35 minutes ago · Like
Kevin Steelwheelz Jackson If we keep our selfs to what is inside the box we will forever be cast in darkness and darkness is ignorance, and state of ignorance is only kept if you never try to step outside the box and find what other options there are to offer
33 minutes ago · Like
Shatila Barnes @kevin i couldnt have said it better...eventually there will be an object whose exact definition and purpose is to be unstoppable and immovable...the closest thing to that rite now is a freight train...its a force that USUALLY only moves or stops by its own power...but whether its stationary or in motion it is still a force
29 minutes ago · Unlike · 2 people
Um Juss Sayin so then its not immovable if its traveling a path.......and if its unstoppable then it cant b stationary.......GEESH.......i never liked thinking in the box .....i stay on the outside thinking pondering wondering seeking searching......never said u didn know oxymoron......but combine they bring a truth not a possibility........HAHAHAHAHAHA......SO LET ME GET THIS RIGHT......U SAYN THERE CAN BE AN UNSTOPPABLE IMMOVABLE FORCE THATS STOPPABLE AND MOVABLE......HAHAHAHAHAHA.......YEA OK......if sumthings on a path then its moving.......period.......if sumthing is immovable then it cant be moved......if u move it or stop it then u change wut it is.......
18 minutes ago · Like
Kevin Steelwheelz Jackson There is the box thinking because if you think of something being immovable as something that is stationary then you are thinking like everyone else. Thinking outside the box makes you realize that if you are "moving" in a straight line then nothing can make you "move from that straight line websters definition is, incapable of being moved; fixed; stationary.
2.
incapable of being influenced by feeling; emotionless: an immovable heart; an immovable tyrant.
3.
incapable of being moved from one's purpose, opinion, etc.; steadfast; unyielding.
4.
not subject to change; unalterable.
5.
not moving; motionless.
6.
Law .
a.
not liable to be removed, or permanent in place.
b.
(of property) real, as distinguished from personal.
7.
not changing from one date to another in different years: Christmas is an immovable feast.
–noun
8.
something immovable.
9.
immovables, Law . lands and the appurtenances thereof, as trees and buildings.
10 minutes ago · Like
Stack Starve Yall going hard without killa
Kevin Steelwheelz Jackson Number 3 by itself shows that it is possible to be moving just as long as you are not moved from your goal you are immoveable, so you can be unstoppable and unmovable because you are one a path that no one can sway you from
Kevin Steelwheelz Jackson Thinking outside the box helps you realize nothing in this world has one purpose and one definition because we all have seperate interpretations of the same things. So like i said before it maybe impossible in the eyes of many until the person of great faith finds the answer and gives tangible evidence that will bring a broader spectrum of thinking to the masses
6 minutes ago · Like
Shatila Barnes @kevin, I agree@BIG, Nobody said the immovable object was travelin a path for example a steel wall....and can u stop a steel wall from not moving...doesnt that make it unstoppable...cause if i aint mistaken one way to define stop could mean to prevent...@Kee lolz
Shatila Barnes Or can u stop a freight train...unstoppable...can u make it move...immovable
