Thread: Over tightening oil and fuel filters
Results 1 to 17 of 17
  1. #1 Over tightening oil and fuel filters
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    I am a diesel tech at a coal mine, and at a coal mine the mechanics only work on the equipment owned by the coal mine. At this coal mine the part of the shop I work in we only work on the big equipment (any over the road truck or smaller we don't touch). We do all of our own oil changes (in other words we don't have a special crew for this). What I hate is when I go to remove the oil filters or fuel filters and the guy before me has made them so tight that I can get the dang thing to come off. The oil and fuel filters are the same as the ones on an over the road truck, just a little bigger and more of them. I don't see why they can't just hand tighten them and call it good. I know of certain people out there that use the filter wrench to get them tight, and when they do this they get them way too tight. I have taken off fuel filters where I have used a 24" chain style filter wrench and I couldn't move it with my arm strength (I am not one to brag ever but I am not a weak guy). I had to sit on my butt and use both of my legs and even then I could hardly get it to move. This particular time took me over an hour to take off two fuel filters. I have them completely shredded. I have seen where guys at work have had to drive a bar through the filter and put a pipe on the bar to get the filter to move. This is very aggravating when this happens. I like when I can take a normal filter wrench and spin the filter loose with no effort. Sorry for the odd vent but this just pisses me off at work.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  2. #2 Re: Over tightening oil and fuel filters
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    I hate that too...
    What is so hard to under stand hand tight then another 1/4 turn DONE!.
    My last 4 oil changes a little tug then filter is lose. no need for a wrench
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #3 Re: Over tightening oil and fuel filters
    Saraland Alabama
    seems fairly common with filters, and I have seen some leak from over tightening (or my favorite on a vette it cracked the boss)
  4. #4 Re: Over tightening oil and fuel filters
    Oklahoma
    I service a lot of vehicles myself and one of my worst cases came from walmart. That sucker was on there so friggin tight that I even struggled with a filter wrench, the rubber strap type which grip, in my opinion better than any out there. And the filter was totally crushed and tore up by the time I got it off.
    Where are you located? I would love to snag a job like that. I guess it would help if you are diesel certified though?
  5. #5 Re: Over tightening oil and fuel filters
    New Salem, ND
    Hmm I thought I had my location set to show up. I am located in New Salem ND, but I work in Beulah ND.
  6. #6 Re: Over tightening oil and fuel filters
    Oklahoma
    Quote Originally Posted by Andrew_99GTP View Post
    I checked but didnt see it at the time, but Im kinda multi-tasking here at work and I could have very well missed it.
  7. #7 Re: Over tightening oil and fuel filters
    New Salem, ND
    Nope I went in to my profile and setup my loaction
  8. #8 Re: Over tightening oil and fuel filters
    PA
    Yeah, I agree 100%. I do all my own oil changes, so it isn't normally an issue. But if I am working on a buddies car, or a new-to-me car, I ***** up a storm when I can't get them loose. I don't own oil filter wrenches because I don't need them when I put the oil filters on.
    And if anyone knows anything about rubber gaskets, they know that over tightening them is not doing any better than slightly snug. The only advantage to tightening them would be so they don't vibrate loose. But I can't see that being much of an issue.
    2001 GSE
  9. #9 Re: Over tightening oil and fuel filters
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    WALMART is the worse im a lube tech and when i see a fram oil filter i dig out the filter wrenches.
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  10. #10 Re: Over tightening oil and fuel filters
    Moore, Oklahoma
    I do all my own oil changes, and I own a filter wrenchs too. I always tighten mine with a wrench when I do mine (I of course fill the filter with motor oil, lube the seal, and screw the filter on hand tight). I've never had one tough to get off, I just use a wrench, and reverse of removal.
    I've known a few people who have had a filter come loose before, I don't take any chances especially when it has to do with oil and presssure. Thats personal preferance though. I feel more comfortable with a little more tightening with a wrench than by just bare handed. I've never had any problems doing what I do and I have piece of mind too.
    Shawn W. Larsen
  11. #11 Re: Over tightening oil and fuel filters
    Wichita, KS
    I think most people do this is because the car, truck or equipment is not theirs, therefor they don't give a flying F_ _ K if they mess something up.
    I have crushed oil filters with the pliers to get them unscrewed after some service center put it on.
    I do my own service, so I know it was done right.
    But for the company truck, we have that done by a shop. I have a good shop now I trust, but the shop before would do this, and they would over tighten the oil pan plug, and they dang near stripped out the pan by doing so.
    ~F~
  12. #12 Re: Over tightening oil and fuel filters
    Bastard Reptile's Avatar
    Kansas City, MO
    I've actually had to stab a screwdriver in the side of one with a hammer to get it off....you wanna talk about mad.
  13. #13 Re: Over tightening oil and fuel filters
    Oklahoma
    Quote Originally Posted by Reptile View Post
    Speaking of which. I serviced a vehicle before that had just a couple thousand miles on it and the customer wanted to change out the factory fill. Well one thing lead to another and I had to stab the factory filter to get it off it was on there so tight.
    Ive done one other vehicle that had the factory filter on it and it was the same way.
  14. #14 Re: Over tightening oil and fuel filters
    Saraland Alabama
    I did my inlaws car a couple months ago (after they went to a local quick lube place) and broke 2 strap wrenches on the stupid thing
  15. #15 Re: Over tightening oil and fuel filters
    Wichita, KS
    Strap wrenches suck. I use a bad boy like this one:
    I also use one like it for my ice machine filters. It will get dang near anything off, or destroy it. But will still get it off for you.
    ~F~
  16. #16 Re: Over tightening oil and fuel filters
    St. Louis Mo.
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    There is a bad joke lurking in there somewhere..........
    I think you need to leave a little message on your next filter change to the other morons to remember not to over tighten the filters.....or something a little more sinister perhaps
    James Shafer
    St. Louis MO
  17. #17 Re: Over tightening oil and fuel filters
    Saraland Alabama
    ~F~
    I have used those, and they slip too much or puncture the filter, I prefer the rubber strap wrench (the only real strap wrenches are adjustable and rubber the metal ones are oil filter wrenches and suck)
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Tefba coolant filters GROUP BUY !!
    By bayareagtp in forum Group Buys
    Last Post: 04-07-2008, 10:43 AM
  3. fuel loss
    By janiuay123 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-20-2008, 12:09 PM
  4. Cone filters
    By bat119 in forum General Tech Discussion
    Last Post: 02-27-2008, 06:00 PM
  5. PRJ Gen 3 fuel rails?
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2008, 02:42 PM
