So, I still love my 08 GP, but there are a couple things I am annoyed about. The first is more I'm annoyed at the dealership, the later I'm just annoyed with the audio system.
First, I took the GP into the dealership for a whining noise. I was sure it was power steering, but since it was under warranty, I figured I'd get the problem into the dealership's system in case it compeltely died later. The car has 35,500 miles on it, so I didn't want to take chances. Besides, I can't see the fluid from up top. Turns out, it was just lower on power steering fluid. They said they topped it off and I'm good to go, right? Less than a week later, same noise. I take it back in thinking there is a leak. Well, no leak. The tech said that nobody topped off the fluid when it was in. GRRRRR! That shouldn't be something somebody forgets, especially since it is the only reason why it is in there. The second time I had to leave in there the whole weekend.
OK, the second problem is about the aftermarket stereo system. First, I HATE that cars are made with stereos that can't be easily replaced. I installed the stereo using the Axxess module and everything was fine for a while. The DIC then started to say (a few months later) that there was a charging system failure. Took it to GM and they said it was the stereo. I took the car to a stereo install center (one highly recommended) and they doublechecked everything and said it was fine. All of a sudden everything started to go wrong.
The E-Brake started saying it was on, when it wasn't. The fuel system started reporting it had no fuel. The odometer and guages stopped working. Then the car stops running on the highway. It would idle, but no response when hitting the gas and the power steering stopped working. This all went away after turning the car off, then back on. Took it back to the audio place and they said it was likely because of the Axxess module, and they recommend another one. Why didn't they tell me that in the beginning? Why does GM make it so that I can't just replace that crappy H/U?
Just curious if anybody else has had these problems. I'm about to have the audio people put the factory H/U in the trunk and re-wire some stuff.
