Thread: stealerships
Results 1 to 16 of 16
  1. #1 stealerships
    Mar 2015
    USA
    stealerships
  2. #2 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    simple, blow the tranny up have it towed in, if it cant move any more, they have to fix the tranny lol drain some fluid, burn it up good, top off the fluid and take it in, see it slips.......lol
    and yes, dealers suck like that, charge you to look at it. its there time.
    most shops will charge you as well if you dont have the repairs done there. ye old diagnosis fee.
  3. #3 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    Kemmerer, Wyoming
    I would hook up a scanner and see if there are any codes. If there are any codes dealing with the transmission it should make their diagnoses much easier.
  4. #4 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    SWPA
    They can hold the car if you refuse to pay. A diagnostic fee does not guarantee a diagnosis can be made. You are paying for their time. Every shop is going to charge a diagnostic fee, regardless of if they can find the issue. Some shops will tell you there is a diagnostic fee, and then they will waive the fee if they find and fix the issue.
  5. #5 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    GTP Level Member buickman104's Avatar
    NYC
    Blow the tranny! (pun intended )
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  6. #6 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    These issues with 4T65Es are probably so common, the dealership techs believe this is normal behavior.
    I keed, I keed.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  7. #7 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    You need a higher end scanner to read transmission codes and if you shut off the vehicle sometimes codes will go away and they will just be a history code.
  8. #8 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    simple, blow the tranny up have it towed in, if it cant move any more, they have to fix the tranny lol drain some fluid, burn it up good, top off the fluid and take it in, see it slips.......lol.
    you should have done this first, ^^^^^ then taken it in, now its on record with clean fluid and no issues. kids dont listen. if you want a new one under warranty, kill this one first, then take it in. you did it backwards. you just bring it to them f ed up good. not a intermittent issue
    my 03 gmc truck started to slip in reverse and first gear, you had to stand on the brakes and floor it to make it happen. shop calls me back says its fine, i rip the guy a new asshole and tell him how to diag a slipping tranny, then told him, ill stop my day right now and be there in 20 minutes and ill melt the tranny right in front of them if they cant figure out the issue.
    it took 3 trannys to get it right too, two rebuilds, then a gm crate tranny, and a crate t case and a rebuilt rear end, all with 45 miles left on the warranty.
    moral of the story is, make sure its " broken" when they get it the first time.
  9. #9 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    dont think so. all dealers suck on some level tho.
    ever hear of buyer brothers GMC in fairview? dont let them work on anything you own lol i got story's from hell. its bad when they know you by first name at the service counter right?
  10. #10 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    Indianapolis
    Why don't you make the appointment like a month from now and just beat on the tranny for a month to make sure they replace it. If you just took it in a few days/weeks ago and they checked and everything was "good" to them, wouldn't it seem fishy for them to check it again a few days later and its all of the sudden ****ed up?
    2004 GT N/A: 343whp/240wtq, L26, HV3, headers, intake, shifting at 9k rpm, stock bottom end, tuned by me
  11. #11 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    Oct 2013
    michigan
    I can't say I'd be posting on a forum about trying to kill a trans for warranty repair. Just me.
    01 gtp SD headers. gen V swap. hai. zzp 1.0 pcm. 06 Impala brakes. GMPP sway bar.
    01 ram 2500 870hp/1796lbft fmw s467.7 w/n20 old. new 66/86 compounds ????hp/????lbft.
  12. #12 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Best bet is to try to set it up so you give them the car when its at temp hot and having problems and they are able to drive it, hell tell them you'll take them for a ride since you can replicate the issue. They should work with you on that.
    2012 F150 STX
    - Gonna be a race truck
  13. #13 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    GTP Level Member PaintChips97's Avatar
    Apr 2015
    Illinois
    I'm with Scotty, drain some fluid and beat it like a red headed stepchild, if it doesn't have to be towed in you didn't beat it enough
    04 Comp G - a few mods, lots of OEM+ goodness, shiny stuff
  14. #14 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    Mar 2012
    NC
    Neutral drops FTW
  15. #15 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    Go to Aamco Transmissions if you have one, they do free diagnosis for trannys. And I would think that they would be able to work with your warranty.
  16. #16 Re: Dealership Charging Fee After Unsuccessfully Trying To Repeat/Find Mechanical Iss
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    whenever the dealership says they can't duplicate the problem. Have the shop foreman test drive with you as you demonstrate the concern. If he is busy, stay at the service counter till he arrives. Wait them out. When you are test driving with the shop foreman...your vehicle is not on he flat rate clock. The foreman will have to either acknowledge a problem is present or say that is normal operation. If they say this is normal operation and you believe it is not, request a test drive in a similar vehicle (hard to do with a 10yo vehicle)
    2004 comp g
  1. Car died then wait then start then drives then dies - Repeat, wth?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2013, 06:55 PM
  2. new gas or mechanical problem?
    By PrixAngel in forum General Tech Discussion
    Last Post: 03-18-2011, 07:58 PM
  3. L67 Mechanical Specs
    By Swash in forum How To Write-Ups/Tech Tips
    Last Post: 02-10-2011, 09:00 PM
  4. 2002 grand prix charging system issue
    By maverickdog8 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-05-2010, 06:59 AM
