Thread: 2000 Grand Prix GT
Results 1 to 7 of 7
  1. #1 2000 Grand Prix GT
    missouri
    My collant is gradually dissapearing and i dont see a leak anywhere but i do smell coolant after i drive the car even short distances. what could the problem be?
  2. #2 Re: 2000 Grand Prix GT
    lower intake gasket leak. I would change it fast or big problems will start to happen.
  3. #3 Re: 2000 Grand Prix GT
    missouri
    you know for sure thats what it is? i discovered today that there was a little bit of coolant in the exaust pipe. soes that make a difference?
  4. #4 Re: 2000 Grand Prix GT
    yea still sounds like a lower intake manifold gasket leak. Its leaking coolant into the cylinders.
  5. #5 Re: 2000 Grand Prix GT
    GT Level Member Tommyp2010's Avatar
    Poland, Ohio
    Quote Originally Posted by ericp View Post
    This. I have the same car, I had to replace mine when I got it.
    2006 Mitsubishi Evo IX MR
  6. #6 Re: 2000 Grand Prix GT
    MA
    its a common issue on gps unfortunatley. make sure you use the revised gaskets if this does turn out to be your issue. but i would check other possibilities first as this can be an expensive job if you give the car to a shop.
    SMGPFC Member #9
  7. #7 Re: 2000 Grand Prix GT
    missouri
    thank you and do you have any idea how much that will cost to fix if it is the head gasket?
  1. Help with my 2000 Grand Prix GT
    By njbarbiegirl in forum General Tech Discussion
    Last Post: 08-24-2010, 11:28 AM
  2. 2000 grand prix: Need help!!!!!!!!!!!!!!!!
    By dwc1435 in forum Brakes/Suspension/Chassis
    Last Post: 08-14-2010, 06:42 PM
  3. i need help with my 2000 grand prix gt
    By aaroncarroll in forum Off Topic Discussion
    Last Post: 07-12-2010, 02:45 PM
  4. 2000 grand prix gt
    By candt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-01-2008, 10:41 AM
