Thread: Does door courtesy lens have a bulb behind it?
Results 1 to 6 of 6
  1. #1 Does door courtesy lens have a bulb behind it?
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    When unloading a board from the inside of my grand prix I ended up poking the end of it into the door courtesy lens on the inside door panel and broke the (red) lens.
    I just now got around to ordering a replacement online and it arrives today.
    MY question though perhaps silly is... is there an actually bulb behind the lens or is it just a lens cover for reflecting light, like a reflector on a bicycle?
    Also do I have to take off the door panel to mount the new lens?
    Thanks
    Terry
  2. #2 Re: Does door courtesy lens have a bulb behind it?
    My 2000 GTP had a bulb in there because it was half white and half red. Would come on with the door being opened.
    If the whole thing is just red like that ones on our 2002 GT, there is no bulb. They install from the outside, they just pop/push into place.
  3. #3 Re: Does door courtesy lens have a bulb behind it?
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    On sedans, the rears are just reflectors,and fronts are lighted.Coupes are both lighted.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  4. #4 Re: Does door courtesy lens have a bulb behind it?
    Apr 2011
    Palm Coast, Florida
    Mine is a 2001 GTP coupe, the red lens just pops in place, no bulb, took me 10 seconds to change out once I got the part in the mail.
    Thanks
    TC
  5. #5 Re: Does door courtesy lens have a bulb behind it?
    Simple answer is GM stopped most door lights for 2000.
    You can add the wiring and bulb back in because typically that is all that was missing.
  6. #6 Re: Does door courtesy lens have a bulb behind it?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by tcman49 View Post
    Yes. You might get lucky, but I broke a tab when I tried to pry it out.
    Here is what they look like from behind.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. P0650 - Check Engine Light issue, bulb ok, low voltage to bulb
    By jasonnovak in forum General Tech Discussion
    Last Post: 10-08-2014, 10:01 AM
  2. Daytime Running Housing swap from 1 bulb to 2 bulb housing?
    By MK666 in forum Visual/Body Modifications
    Last Post: 06-02-2013, 12:42 PM
  3. Courtesy Lights
    By 98GPGT2D in forum General Grand Prix Discussion
    Last Post: 02-14-2012, 12:40 PM
  4. interior courtesy lights out
    By GTLGDP in forum General Tech Discussion
    Last Post: 11-01-2011, 09:20 AM
