The only differences are tire sizes... Does it matter?
94-04 Mustang
Best Tire : 1994 - 1998: 265/35-18 1999 - 2004: 275/35-18
or 05-2014
Best Tire : 255/45-18
94-04 Mustang
or 05-2014
Yes tire size does matter. I have the 05+ Saleen replica 18x9 wheels with a +30 offset. My car is not lowered and I ran 245/40-18 with no problems for a while, but my car looked like a monster truck because of the wheel gap. Now I'm on 255/45 -18s which look better as far as the wheel gap goes, but I had to have my rear fenders rolled because of rubbing issues. 265 and 275 widths might be a bit too wide on our cars, but maybe some of the other guys might want to chime in that.
But the year of the saleen wheels don't matter? Couldn't I put a 245 45 18 on any year saleen? Any pictures of your salsaleens?
Yes the year matters as far as style and color of wheel you want, but the bolt pattern that you want is 5x114.3. That's the bolt pattern that will fit our cars, and yes, 245 45 18 tires will fit on any year saleen that is a 18' wheel. The only thing is a 245 width tire works and looks best on a 9" width or smaller wheel. 245 on a 10" wide wheel will fit when it's stretched, but it ain't gonna look good. Here are some pics of mine: http://s1337.photobucket.com/user/jacobjoel/slideshow/
the 04 and older fitment have the offset that's numerically closer to our OEM rims. (38mm and 42 iirc)
those things certainly appear to be past the lip...im guessing you have craploads of room between the sidewall and the strut tube with the 30mm
Thanks, and no they ain't for sell lol. I had use magic to get the center caps on lol, no I just reversed the center caps from the inside that the wheels came with and then popped the OEM Pontiac ones in to them. And I think there's a few guys on the forum with 97-03s running saleens.
i know you're a super smart guy and all, but i think you're missing part of the equation: the wheel width.
at 9" wide with a +30mm offset you'll have a nearly identical inset (9mm closer to strut) from stock wheels, but it'll poke another 53mm.
comparing 16x6.5 +52mm (225/60R16) to 18x9 +30mm (245/45R18):
http://www.willtheyfit.com/index.php...et2=30#contentDiameter 676.4mm 677.7mm
Circumference 2125mm 2129.1mm
Poke 30.6mm 84.3mm
Inset 134.6mm 144.3mm
Speedo error 0% -0.19%
Reading at 30mph 30mph 29.94mph
Reading at 60mph 60mph 59.88mph
Ride height gain 0mm 0.65mm
Arch gap loss 0mm 0.65mm
i've been using it more and more recently now that i've been trying to theoretically figure out what my car will fit without actually having a set of wheels to test fit.
