Thread: wanting help: 3.5 pulley ZZP Downpipe/Ubend
Results 1 to 13 of 13
  1. #1 wanting help: 3.5 pulley ZZP Downpipe/Ubend
    Feb 2015
    california
    so im wanting the 3.5 pulley from ZZP. They recommend their Downpipe before going to a 3.5 pulley. My question is which Downpipe would I want to get? what size? and would i get the 02 Bung not sure what it would do... Im in cali so emissions is on my mind. I also decided i might as well get the U bend delete as well but the 02 Bung option is there again... I dont want to pay for anything that i dont need. Help!
  2. #2 Re: wanting help: 3.5 pulley ZZP Downpipe/Ubend
    ca sucks, you'll need a carb approved cat installed in the down pipe.
    lets think about this, if you change the down pipe, why would you also need a U bend delete? the u bend is in the stock down pipe.
    now you can do a u bend delete too if you dont want to get the new DP and a new cat.
    i went to a muffler shop and bought 12 inches of pipe a o2 bung, and a flange, (for 20 bucks) then welded it up my self and installed it.
    zzp sells a u bend delete for what 50 bucks? im sure a shop could make and install one for that much.
  3. #3 Re: wanting help: 3.5 pulley ZZP Downpipe/Ubend
    Hell I have a brand new ubend delete from ZZP I'll sell for cheaper then ZZP if you go that route.
    04 Comp G.
  4. #4 Re: wanting help: 3.5 pulley ZZP Downpipe/Ubend
    SE Level Member MM06GT's Avatar
    Jan 2013
    SF Bay Area
    Yes as said, it sucks for us here in Cali when it comes to emissions, but as a suggestion, buy ZZPs catless downpipe and keep you OEM downpipe for when it comes time to smog your car. If you do the swap out yourself it shouldn't take you more than 30-35 mins to get under the car and do it yourself every 2 years for your smog test. It's worked for me the last 4 years.
    Silver 06 GrandPrix GT: K&N cai//3" catless DP//SS plog//Rear ported Mani//AL xp 104s//180* TS//ZZP 10.5 wires//TB HS//ZZP 3.2" MPS//E85//50lb injectors//1.9 YT rr//90lb sprs//Impala DP brakes//AF scan gauge//Mini AFR//BLK 18x9 saleen replicas//Overkilled.
  5. #5 Re: wanting help: 3.5 pulley ZZP Downpipe/Ubend
    Feb 2015
    california
    Quote Originally Posted by MM06GT View Post
    Really? The catted downpipe wont pass?
  6. #6 Re: wanting help: 3.5 pulley ZZP Downpipe/Ubend
    Feb 2015
    california
    Im wanting to upgrade the pulley to 3.5 or 3.4 would just the U bend delete be enough?
  7. #7 Re: wanting help: 3.5 pulley ZZP Downpipe/Ubend
    Jan 2013
    SF Bay Area
    Yes, the catless downpipe will not pass smog, but that is why you keep your OEM downpipe in storage. When it comes time for you to smog your car, you change out your catless to your OEM and smog the car then which back to your catless after you pass your smog test. Also what year is your car....... if you are an 04+, you're going to need a lot more than a downpipe to get down safely to a 3.4/3.5 pulley. I think you might what to read this: http://www.grandprixforums.net/threa...00-Powered-Car!!
  8. #8 Re: wanting help: 3.5 pulley ZZP Downpipe/Ubend
    Jan 2013
    SF Bay Area
    Quote Originally Posted by silenthaven View Post
    To clarify, it won't pass the visual inspection.
  9. #9 Re: wanting help: 3.5 pulley ZZP Downpipe/Ubend
    i did say that as well in my first post.
    zzp's catted dp is not carb approved.
  10. #10 Re: wanting help: 3.5 pulley ZZP Downpipe/Ubend
    Feb 2015
    california
    I have a 02 gtp
  11. #11 Re: wanting help: 3.5 pulley ZZP Downpipe/Ubend
    you'll likely get a o2 code from the cat less d/p. you can get that tuned out so your not looking at the check engine light stuck on.
  12. #12 Re: wanting help: 3.5 pulley ZZP Downpipe/Ubend
    GT Level Member 04GTP4dr's Avatar
    Jun 2015
    hastings, Nebraska
    Redcompg how much you want for that u delete? ?
  13. #13 Re: wanting help: 3.5 pulley ZZP Downpipe/Ubend
    Quote Originally Posted by 04GTP4dr View Post
    $40 shipped if your in the U.S..
    Pic in this thread
    http://www.grandprixforums.net/threa...-Ubend-del-etc
    04 Comp G.
  1. WTB Ubend delete or downpipe
    By K Kraziee in forum Wanted To Buy - Parts
    Last Post: 05-18-2013, 11:41 AM
  2. 3.25 pulley / 3 in downpipe
    By gtpinsc in forum General Tech Discussion
    Last Post: 10-03-2008, 05:07 PM
