Thread: 08 Grand Pix GXP
Results 1 to 7 of 7
  1. #1 08 Grand Pix GXP
    SE Level Member georgeo's Avatar
    Jun 2014
    Colorado
    Hey all,
    I'm having difficulty finding a quality replacement front strut for my 08 Grand Prix GXP. I have searched the Delco site, several others. Delco has the loaded struts for an astronomical $400+ apiece. The others I have seen are not something I want to go through the expense and effort to install a low quality part without the related hardware. Any help would be awesome.
  2. #2 Re: 08 Grand Pix GXP
    Nov 2012
    Madison
    You might want to go with the AC Delco FE3 struts. They come on the 04-05 CompGs.
    RockAuto has them for 31 for the rear(close-out private label) and 110 for front.
  3. #3 Re: 08 Grand Pix GXP
    Oct 2011
    Toledo, OH
    And they won't fit. Perch heights are different. FE1-3 are interchangeable, FE4 aren't.
    7"
  4. #4 Re: 08 Grand Pix GXP
    Jun 2014
    Colorado
    I do appreciate you folks taking the time to reply. I have found the Delco units (FE4 front) on Amazon for $210 and some change, free shipping...I'll just have to use some of the old hardware, springs mostly and purchase the new strut mounts as well...next stop, Overkill muwaahhahah...
  5. #5 Re: 08 Grand Pix GXP
    I live here. DirtDog's Avatar
    Jun 2012
    Go dieblo tune over overkill. Overkill is awesome at the 3800 and awesome with the 4t65e. But dieblo does better on the ls4
  6. #6 Re: 08 Grand Pix GXP
    Aug 2013
    McDonald PA
    Quote Originally Posted by DirtDog View Post
    I would rather have wills transmission tune and get some power than with a diablo rape my trans and get a **** ton of power. Just my opinion
  7. #7 Re: 08 Grand Pix GXP
    Jun 2014
    Colorado
    You are right, they would not fit. The FE4 suspension is a totally different deal. I did end up buying the Bilistien struts from amazon and they fit perfectly. Something i found to be odd about this front suspension is that there is no adjustment for caster or camber by elongated holes in the strut to knuckle mounts or elongated holes in the tower mount. I think this is cool as hell especially for being able to change the struts at home and having to get it aligned.
  1. Replies: 184
    Last Post: 03-30-2014, 07:51 PM
